What is the best amount of cores for streaming and gaming.
i plan to play DayZ and do some streaming.
i want to use either an Amd fx-4350 or fx-6300 or an intel core i3-4130
I am also going to upgrade so this will need to be the bare minimum
Fx-6300 or Fx-8320 if you can afford it will be the best.
just Ben Dover it
DEAR GOD, THANKS FOR GETTING ME TO GOOGLE THAT
Also maybe look into a Live Gamer HD capture card. That is if you want to get into streaming hardcore, not really needed, but coooooooooool.
dayZ and streaming? Intel Xeon E3-1230V3.
