Hey, I am building a PC for a photographer to run Photoshop + Lightroom, to last for 10ish years, and I am looking for critique, or point out something I am not considering regarding the parts selection
I am going to for an AM5 based build because the APUs are a great value, and it has great update upgrade potential (zen 6/7)
Upgrading from i7 4930k (6 ivy bridge cores) + GT 710 + 48GB RAM
Country: Greece, prices include VAT
PC Parts
CPU+GPU+CPU Cooler
Ryzen 7 8700G (8 Zen 4 cores + 12RDNA CUs), 254Euro
This seems APU looks to provide excellent value, it is more CPU focused rather than GPU focused which is what is needed, and it also comes with a simple included cooler
if I wanted something faster, I would have to go for Ryzen 7 7700 + RX 7600 for double the price
Motherboard
ASROCK B650 PG LIGHTNING 140Euro
Has lots of USB IO and VRM
The only downside is that it does not support PCIE 5
RAM
64GB 6000Mhz CL36 198Euro
or
64GB 5600Mhz CL36 174Euro
I am not sure if going to expensive RAM is worth it, I am thinking of going for the 5600Mhz option to both same some money, and have better system stability.
The main advantage to the 6000Mhz is that it will be better when/if the CPU is upgraded.
Note: the 8700g has an officially supported speed to
SSD
Kingston NV3 54Euro
This is decent gen4x4 SSD, the SSD will be used for OS + programs, not for storing data, so there is no need to go for a high durabiltity drive
PSU
BE QUIET PSU PURE POWER 12 M 750W 116Euro
This seems to have good reliability and safety features based on reviews, it is definitely a bit overkill but, buying smaller capacity does not save the much money, and it allows for future upgradability
the 650W costs 104
the 550W costs 86E
CASE
BitFenix Shinobi XL (reused from old build) 0 Euro
Has 4 USB 3.0 5GBPS front panel connectors, I may have to connect 2 of them to the internal USB3 motherboard connector and the other 2 to the internal USBC connector with an adapter
