So if you guys already dont know, dynamat is something alot of car audio enthusiast use to help reduce unwanted vibrations in their car chassis that might be cause from their speakers, mostly the sub woofer.
what it does(from what i understand) is absorb sound vibration, turning it into heat.
i figure this can also be employed in a computer case to reduce the sound coming from fans, mechanical HD's and whatever else components generate sound.
some people have suggesting using cheap insulation materials for roofing as a dynamat alternative but there are stories where the insulation material will fall off if mounted vertically. Also those are made with tar which i dont think is safe in a home setting or in your computer,(But what do i know?) You can go ahead and use dynamat but i was wondering if anyone knew of a cheaper or even cheaper/bulk alternative.
does anybody know if dynamat or a cheaper alternative will make a difference? what kinda heat production from the noise suppression materiel can i expect? it it negligible?
vs
alternatives:
Accumat http://www.scosche.com/accumat
B Quiet/Brown Bread http://www.b-quiet.com
Dynamat http://www.dynamat.com
edead http://www.edesignaudio.com/ep2/edead.htm
Noise Killer http://www.noisekiller.com
Quiet Coat http://www.quietcoat.com
RAAMmat http://www.raamaudio.com/
Second Skin http://www.secondskinaudio.com/
VBlok http://www.cascadeaudio.com
msds of the peel & seal
http://www.cofair.com/msds.aspx
what do you guys think? im thinking of giving this a try in my pc with the super loud r9 290
