PC is done, but still a few problems
Hey guys, Like to thank a few who gave me a hand on the forums the other day, i finally finished my first PC today. I am not proud of the Cable management though, but i'll be taking it somewhere to get those and some minor problems fixed.
Heres what i am having issues with, and as far as i can tell, nothing immediate. (BTW this is a NZXT Phantom 410 case)
-Heat: It idles around 45'c, but when playing Rust today i noticed it went up to 65'c and you can feel the heat off the side. I am not sure why its doing this honestly, maybe i need more fans?
[fixed]-2TB HDD: I installed a 2TB HDD but for some reason it doesn't show up in My Computer as a Drive, It only shows up in Bio's as a bootable drive, but nothing else. I may have a look at this tonight because i probably have it plugged into an SSD slot instead of a regular HDD slot.
[fixed]-Front USB's: I also need to figure out what is up with my front USB slots, I have it plugged in i think, but i think the cable may be damaged. Not entirely sure.
-'tick' sound: Every now and then when i was playing rust i would here this 'tick' or 'crack' within the case, I am not sure if this is the computer settling down or what.
anyways if you guys wanna put in your Input on any of that so i can see what can be done later tonight, that'd be great :)
my pc does that too scares the hell out of me i think its just it cooling down.
Alright
I fixed the 2TBB and the front USBS, I am not sure if that tick sound is it cooling down or not..would make sense. Nothing else is making this pc work harder than rust atm..no idea why...
Another problem i figured out (Which is more of a lack of parts.) Is i need a power cable for the Optical drive. The one that goes to the HDD's just doesn't reach so i may need to buy a separate one
What is your cpu and are you using an aftermarket cooler? 45 seems a bit warm but its not bad.  65 is not bad at all for max. A lot of headroom if you ended up overclocking.
The USB ports can be dificult. make sure you dont plug it into a firewire port. That will cause damage to the port and also wont function. USB and Firewire looks exactly the same so chec the manual.
You can but extentions for the optical drive easily. $6-15 at any good PC store.
The Ticking you hare hearing is most likely the Case. But it can also be a failing HDD along with even componants in your system blowing. Just keep an eye on it but most likely just the Case warming and cooling. I own a Phantom 820 which is the grand daddy of Phantom cases and boy does it make a noise when the system is put under load. Or even if I put the air con on. It freaked me out at first as well.
You had the FX-6300 right?  I forget...
TBH 65c is a fine temperature for a loaded CPU, especially with stock and cheap hs/AIOs.
Try to find the source of the ticks?  Idk.
Imho, if you can feel the heat on the side of your case, something is to warm. What kind of fan set ups are you s using in your  case???  The tick almost sounds like a bad fan, or maybe your power supply???  Decent air flow is a must imho, Case fans are really inexpensive, if it were me, I would load the case up with decent fans, and make sure you have great air flow.
There's an awful lot of plastic on that case, so as others have said, the ticking could just be the plastic expanding and contracting with the heat.  Or a bad hard drive.  Or a bad fan.  But probably the plastic expanding.
The heat is likely down to air flow, but it's nothing out of this world.  How many fans do you have installed, and where are they?  Plus, how are they oriented (intake/exhaust).  Also, that case appears to have a built in fan controller, so you can try cranking that baby up and see how much it helps.
