Can someone link me to this thread if it exists?
something about pump should lye beneath any reservoirs one has in the loop. and other key positional factors for prime fluid flow
Have a look at this guide https://forum.teksyndicate.com/t/water-cooling-for-noobs-the-all-in-one-guide/34631
Yes you want you pump under your res and the next item in the loop to reduce the chance if it running dry. You don't want the pump to have to pull liquid into it and push it out.
