Hey guys, let me just start of by saying this is my first post on the forum and hopefully you can help me out. So My birthday was coming up and I started researching how to build a computer just for fun and I also wanted know wether it was hard to build a computer and also to take my knowledge of computers that little bit further. I just need some advice on the build that I have in mind, I live in australia so keep in mind that I can't go to new egg or anything like that and also that i don't really wanna spend more then $750 even though its a birthday present because last year i got a mac for school (boy was that pricey)
anyways enough of my talking (you don't even have to read that) I had a few questions about this build. This is meant to be a 90% gaming PC maybe...MAYBE 10% rendering/editing
MotherBoard: ASrock B75M R2 (about $75 with shipping) - http://www.mwave.com.au/product/asrock-b75m-r20-motherboard-aa34572#detailTabs=tabSpecifications
CPU: Intel Core i3 3220 (maybe $145-$150 with shipping NOTE-went with the i3 3220 instead of the amd fx-6300 because I can later on upgrade the i3 into and i5/i7) - http://www.diycomputers.com.au/check.asp?ProdId=11553
GPU: AMD radeon HD 7850 2GB GDDR5(about $185 with shipping) - http://www.jw.com.au/vtx3d-amd-radeon-hd7850-2gb-gddr5-gaming-graphic-card-p-53732
RAM: 8GB of super sexy DDR3 1600mhz Ram (corsair vengeance, $115, had an extra $40 to spend so I'm also getting arctic ram coolers for $20. The ram that I was originally gonna get was $90) - http://www.computeralliance.com.au/search?search=DDR3%208GB%20(2x4G)%20Corsair%201600MHz%20Vengeance%20CL9%20RAM%20Kit%20PN%20CMZ8GX3M2A1600C9
Ram cooler: Arctic thermodynamic ram cooler (twin pack, $20.)
http://shop.phasercomputers.com.au/collections/ram/products/arcticcoolingthermodynamicramcoolerforddr2ddr3sdrammodulestwinpack26ccoolerthanstockedramcoolerforoverclockers
HDD: Western Digital Blue 1TB (about $75-$80 with shipping also don't wanna run out of space and from what I understand WD blue is the norm) - http://www.pccasegear.com/index.php?main_page=product_info&products_id=21231
PSU: Antec EarthWatts 650w (about $90, Should be fine, its like $3 more expensive then a corsair CX500 so I thought I should go with this) - http://www.allneeds.com.au/prod969.htm
Case: Xigmatek Asgard 381($50) - http://shop.phasercomputers.com.au/products/xigmatekasgard381blkmtcase
Don't need an Optical Drive (Moniter/TV has built in dvd drive and xb1 has blu-ray so I'm set with that)
Total = $710, just what i wanted to spend
I have a question about this build
Will the MotherBoard (along with everything else) be able to fit in the case. The website says the motherboard support is ATX but the motherboard's form factor is mini ATX does this matter?
Thanks for reading this and I hope you can answer my question that would be great!
