I want to build a new PC so that i can play the new games like bf4 and DayZ standalone but i don't know what to put in it. I kind of want to put 1 gtx 760 so that i can later SLI it but i want to know your opinion. This would be my first PC Build but i know what i am doing because i have helped friends i just need a parts list now. I don't want it to be too expensive. Any help is appreciated thanks.
if you can give a dollar amount, what peripherals are included in the amount/ what you already have. that would help.. cause whats not to expensive to u could be super expensive or visa versa for someone else
i mean i guess around $900-1000 and i already have a mouse and keyboard
http://pcpartpicker.com/p/2o553 totalled at 634 but with no monitor or headset... pretty much as long as u choose a low response time, high freq and what not youll be good. headset wise i use steelseries siberia v2 frost and love them but to each there own
basically its a dumb down version of what i have... fx 8350, gtx 780, 16gb 1866mhz.... and i realized i forgot a hard drive..... i use a sshd 1Tb they run around $100
okay awesome thanks i appreciate it!
what sshd do you recommend?
changed mufforz' build around:
Non-SLI: http://pcpartpicker.com/p/2ozkA
SLI upgradeable: http://pcpartpicker.com/p/2ozm6
thanks guys i got my build done and I'm planning on making it in a corsair carbide series air 540 case I'm just looking for a good cheap monitor that is good for gaming.
chears have fun
thanks for all the help
