http://www.dateks.lv/en/grozs?content=q1ZKL8qvKlayqlayNDC2MAIxirMTM0uAQoa1OkBBEwsTdEFzEzMLYwxBQyMzU3RBM3NDYwztFiZGJmgqa2sB
This is my build:
Motherbord: Asrock Z97 Pro3 --> I amnot shure about this, the only important thing is I need MOBO with http://www.renesas.com/ USB3 Controller (it is because I have BlackMagick Capture card and it works just with renesas USB3 controllers) - is there such MOBO?
CPU: Intel Core i7-4790 (3.6GHz, 8MB Cache, LGA1150) (is it possible to OC or for that I need CPU with K? it this do not OC, then I also do not need MOBO for OC! if it OC, then)
PSU: Corsair 550W, RM550, 80+ Gold, Modular ---> maybe overkill, but i want it to be 0RMP Fan if power consumption is LOW.
RAM: Kingston 16GB, DDR3, 2133MHz, CL11, Kit of 2, HyperX Beast
HDD: Seagate 2TB, 7200rpm, 64MB, Sata III, Barracuda
SSD: A-Data XPG SX900, 256GB, SATA3 + 3.5'' adapter
GRAPHICCARD: for now none, just integrated iGPU (I use Sony Vetas for Rendering)
Please suggest me something, and give advice!
