http://uk.pcpartpicker.com/parts/partlist/
or
http://uk.pcpartpicker.com/p/VxCyHx
are these machines up to scratch, able to high end perform with high fps in all or most games?
thanks, pxseidxn
or
thanks, pxseidxn
First build will do ultra in most games with 40-60 fps at 1080p,and the second build will do ultra with 50-60 fps at 1080p.The only difference is the second build will be able to handle productivity tasks way easier since it has a octa core cpu so it really depends on what you're doing.
they're both octa cores?
