ziomario@DESKTOP-N9UN2H3:/home/mariozio# lspci -nnv
00:00.0 Host bridge [0600]: Intel Corporation 8th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] [8086:3e30] (rev 0d)
Subsystem: Gigabyte Technology Co., Ltd 8th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] [1458:5000]
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=10 <?>
Kernel driver in use: skl_uncore
00:01.0 PCI bridge [0604]: Intel Corporation Skylake PCIe Controller (x16) [8086:1901] (rev 0d) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 16
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: 62000000-650fffff
Prefetchable memory behind bridge: 0000000050000000-00000000600fffff
Capabilities: [88] Subsystem: Gigabyte Technology Co., Ltd Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) [1458:5000]
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [a0] Express Root Port (Slot+), MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [140] Root Complex Link
Capabilities: [d94] #19
Kernel driver in use: pcieport
00:02.0 Display controller [0380]: Intel Corporation Device [8086:3e98] (rev 02)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:d000]
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at 66000000 (64-bit, non-prefetchable) [size=16M]
Memory at 40000000 (64-bit, prefetchable) [size=256M]
I/O ports at 4000 [size=64]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
00:12.0 Signal processing controller [1180]: Intel Corporation Cannon Lake PCH Thermal Controller [8086:a379] (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH Thermal Controller [1458:8888]
Memory at 6713d000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [50] Power Management version 3
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller [0c03]: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller [8086:a36d] (rev 10) (prog-if 30 [XHCI])
Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH USB 3.1 xHCI Host Controller [1458:5007]
Flags: bus master, medium devsel, latency 0, IRQ 125
Memory at 67120000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
Capabilities: [90] Vendor Specific Information: Len=14 <?>
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory [0500]: Intel Corporation Cannon Lake PCH Shared SRAM [8086:a36f] (rev 10)
Subsystem: Intel Corporation Cannon Lake PCH Shared SRAM [8086:7270]
Memory at 67136000 (64-bit, non-prefetchable) [size=8K]
Memory at 6713c000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller [0780]: Intel Corporation Cannon Lake PCH HECI Controller [8086:a360] (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH HECI Controller [1458:1c3a]
Flags: bus master, fast devsel, latency 0, IRQ 127
Memory at 6713b000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [a4] Vendor Specific Information: Len=14 <?>
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller [0106]: Intel Corporation Cannon Lake PCH SATA AHCI Controller [8086:a352] (rev 10) (prog-if 01 [AHCI 1.0])
Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH SATA AHCI Controller [1458:b005]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 124
Memory at 67134000 (32-bit, non-prefetchable) [size=8K]
Memory at 6713a000 (32-bit, non-prefetchable) [size=256]
I/O ports at 4090 [size=8]
I/O ports at 4080 [size=4]
I/O ports at 4060 [size=32]
Memory at 67139000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Kernel driver in use: ahci
Kernel modules: ahci
00:1b.0 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port [8086:a340] (rev f0) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Capabilities: [40] Express Root Port (Slot-), MSI 00
Capabilities: [90] Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH PCI Express Root Port [1458:5001]
Capabilities: [a0] Power Management version 3
00:1c.0 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port [8086:a338] (rev f0) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
00:1d.0 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port [8086:a330] (rev f0) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 00005000-00005fff
Memory behind bridge: 3f800000-3f9fffff
Prefetchable memory behind bridge: 000000003fa00000-000000003fbfffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
00:1f.0 ISA bridge [0601]: Intel Corporation Z390 Chipset LPC/eSPI Controller [8086:a305] (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Z390 Chipset LPC/eSPI Controller [1458:5001]
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH cAVS [1458:a0c3]
Flags: bus master, fast devsel, latency 32, IRQ 129
Memory at 67130000 (64-bit, non-prefetchable) [size=16K]
Memory at 67000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [80] Vendor Specific Information: Len=14 <?>
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation Cannon Lake PCH SMBus Controller [8086:a323] (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH SMBus Controller [1458:5001]
Flags: medium devsel, IRQ 16
Memory at 67138000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller [8086:a324] (rev 10)
Subsystem: Intel Corporation Cannon Lake PCH SPI Controller [8086:7270]
Flags: fast devsel
Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (7) I219-V [8086:15bc] (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Ethernet Connection (7) I219-V [1458:e000]
Flags: bus master, fast devsel, latency 0, IRQ 123
Memory at 67100000 (32-bit, non-prefetchable) [size=128K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti] [10de:1e04] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. TU102 [GeForce RTX 2080 Ti] [19da:2503]
Flags: bus master, fast devsel, latency 0, IRQ 128
Memory at 64000000 (32-bit, non-prefetchable) [size=16M]
Memory at 50000000 (64-bit, prefetchable) [size=256M]
Memory at 62000000 (64-bit, prefetchable) [size=32M]
I/O ports at 3000 [size=128]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Capabilities: [bb0] #15
Kernel driver in use: nvidia
Kernel modules: nvidia
01:00.1 Audio device [0403]: NVIDIA Corporation TU102 High Definition Audio Controller [10de:10f7] (rev a1)
Subsystem: ZOTAC International (MCO) Ltd. TU102 High Definition Audio Controller [19da:2503]
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at 65080000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
01:00.2 USB controller [0c03]: NVIDIA Corporation TU102 USB 3.1 Controller [10de:1ad6] (rev a1) (prog-if 30 [XHCI])
Subsystem: ZOTAC International (MCO) Ltd. TU102 USB 3.1 Controller [19da:2503]
Flags: bus master, fast devsel, latency 0, IRQ 126
Memory at 60000000 (64-bit, prefetchable) [size=256K]
Memory at 60040000 (64-bit, prefetchable) [size=64K]
Capabilities: [b4] Power Management version 3
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU102 UCSI Controller [10de:1ad7] (rev a1)
Subsystem: ZOTAC International (MCO) Ltd. TU102 UCSI Controller [19da:2503]
Memory at 65084000 (32-bit, non-prefetchable) [size=4K]
