Hello, I am new to setting up VMs with GPU pass through. Is there a specific way to get an igpu to work via MaOS specifically? I’m using Mac in a Box on Unraid. The OS loads fine but any attempt to select a gpu option other than virtio doesn’t even allow me to view the VM’s GUI.
Macos drivers are called kext. I assume there is no driver for a modern igpu in x86 macos since last x86 hardware supported by that is like 2020 or so. You will need to check the forums of people making Hackingtosh (running macos on non-apple hardware) to see if thet have kexts that work on that igpu. Or failing that, what hardware you can actually use on MacOS and where to source the drivers if necessary
I think you are stuck with sourcing a dgpu, if your system allows it. There are not any iGPU drivers for current processors in Intel Mac OS and I havent seen workarounds for the current Core series. I think the latest supported iGPU was from Canon Lake processors (Intel i-processors 10th gen). You could spoof hardware IDs to run a later 11 gen iGPU, but it is most likley unstable or you’ll end at a black screen depending on the MacOS version.
RIP, I’ve mostly given up on this route as it seems like hackintosh support is dying at a steady pace considering apple is no longer supporting x86 on their latest OS.
Its not that bad, if you use paravirtualisation and have access to a 6700 or 6900 XT AMD GPU and if your USB controller play ball.
I run Mac OS 26 on a WRX80 Threadripper virtualised in Proxmox and fortunately the onboard USB-controller work out of the box at full speed. And thats all I require.
Unfortunately all the nice Desktop features are tied to specific hardware (Airplay for example) and with the last two versions Apple cut a lot of hardware support. Bluetooth for example used to be plug&play via USB dongle, now you have to map your USB ports / controller to get past USB 2 speeds, to enable bluetooth or even USB Audio. Now you have to spoof a specific Mac machine and generate a Mac serial nr. + set your Ethernet as build-in so that you can connect to Apple services (icloud, imessage etc.). There are a lot of fiddly bits, to get most of the features working.
Yeah, hackintosh/KVM-MacOS is dying out. Unless you already have the hardware to run it, it’s probably not worth it any more to purchase anything since support will die out.
Last year I’d have recommended to just buy a mac mini M4 since those were a bargain, but that’s no longer true. If you can find a good deal on a second hand Apple Silicon device, though, that’s probably the way to go. A mac mini or M1-M3 macbook doesn’t take up a lot of space, sips power, and can double as a power efficient home lab.
