I have a question about the title-mentioned GPU.
I wanted to buy it for myself, but I gave up when I realized it has a external 5v 3pin ARGB Sync cable that needs to be connected to your motherboard - and my motherboard doesn’t have those headers.
I asked on multiple subreddits if the GPU’s RGB can be synced to the rest of the PC without the cable. I know you can control the RGB using their software, but not sure about actual syncing via OpenRGB/SignalRGB.
The answers I got are;
Yes you can sync without cable
No you can not sync without cable
I looked at a bunch of videos and pictures of builds having that GPU, a lot of them have the cable disconnected, yet the RGB is synced to the rest of the PC.
So now I am confused, what is the truth and what isn’t.
Any GameRock owners to confirm, please?
