Hello
I bought on eBay USA a brandnew KVM (PAAG-E3124B) and didn’t think about the Power Plug ^^
I live in Germany and can’t use the American Power plug version and was wondering what i should do to get the KVM working.
Is there a EU Cap (when i browse your shop i can see that there are multiple different caps possible) for the Power Adapter available that i could order on Amazon or somewhere else that delivers to Germany in a decent timeframe?
Can i use a generic Power Adapter instead? If yes could you say what Specs i should look for so i can find one on Amazon (or if you could link me one from Amazon that would be amazing)?
Thank you in advance and keep up the good work :)!
David
With the compatibilty in mind I checked the part number on the power adapter (6A-181WP12) and found one on ebay Germany where i can steal/repurpose the german “Cap” from (and potentially a spare power adapter incase the KVM one breaks).
Thanks again for the Explanation that its 230V compatible!
David
cool, 4K@144Hz and VRR, I wonder if this also works with an adapter to HDMI 2.1, I use an LG Oled.
Can you please give feedback in 3-4 weeks how satisfied you are with it?
that’s sad, I had bought an Aten CS1924M shortly before I bought the LG, I should have planned better, a simple USB Switch would have been cheaper.
But luckily the LG has 4x HDMI and a remote control…
service remote + rs232 switching ftw on the lgoled. but not all the hdmi ports are equal, at least not on mine. only 1 or 2 seem to work best for computer control. the others have this weird glitch effect, no idea what it is but loads of reddit threads discussing it
