Overclocking Intel Core 2 Duo E4600
I have been searching for tutorials but nothing came up. maybe on of you knows
Bus Speed:  201  Mhz
CPU core 1: 2408 MHz
CPU core 2: 2408 MHz
Ahh... The good old days of cranking the bus speed for more GHz. It's more fun, as you have to balance out ram speed, as FSB affects more than just CPU clocks. All you do is make sure the multiplier is at its highest setting and slowly raise FSB. You may want to lower your RAM speed to avoid instability. Keep an eye on temps.
i overclocked it to 3 GHz and did not need more voltage. It works vell at 65 C on stress test max
