Hey Gang
I think I might be having a few issues with a system I decided to overclock after having run at stock setting for 3 year (LOL).
The Temps on the CPU are kind of worrying me as the idle temps are 48-50 and when I run prime95 the CPU temps BOLTS up to 90+ in less than 2 mins and I stop the test at that point. (I'm scared I'll Kill the CPU :P)
I wanted to get some feedback on if these setting are good or can I improve the temps by making a few adjustments.
Here are my specs and OC settings, I hope I've included all the neccessary info:
i7 950 @ 3.02 (4.01 overclocked)
Gigabye GA-X58A-UD3R rev 2.0
Coolermaster Silent Pro Gold 1200W psu
Noctua NH-U12P SE2 CPU cooler (Push/Pull Config)
Corsair XMS3 — 12GB Triple Channel DDR3 Memory Kit (CMX12GX3M3A1600C9) 9 9 9 24
Rating: PC3-12800 (1600MHz)
WESTERN DIGITAL 1TB 3.5" BLACK 64MB SATA3 WD1002FAEX
WD 500GB HDD x 3 (Storage Only)
EVGA GeForce GTX 580 Superclocked 1536 MB GDDR5 PCI Express 2.0
Creative X-Fi Titanium Fatal1ty Pro
My Current OC Setting are:
CPU Clock Ratio.....:20
CPU Frequency .....(Ghz).....:4.0
Intel® Turbo Boost Tech.....:[Disabled]
CPU Cores Enabled.......:[All]
CPU Multi Threading......:[Enabled]
CPU Enhanced Halt (C1E).....:[Disabled]
C3/C6/C7 State Support.......:[Disabled]
CPU Thermal Monitor..........:[Enabled]
CPU EIST Function............:[Disabled]
Bi-Directional PROCHOT....:[Enabled]
irtualization Technology.....:[Enabled]
Uncore & QPI Features [Press Enter]
QPI Clock Ratio*..........:36
QPI Link Speed* .........(Ghz):7.20
Uncore Clock Ratio.........:x17
Uncore Frequency.......(Mhz):3,4
Isochronous Support........:[Enabled]
Base Clock (BCLK) Control*......:[Enabled]
BCLK Frequency (Mhz)*......:200
PCI Exxpress Frequency (Mhz)......:103
CPU Clock Drive (mV)........:700
PCI Express Clock Drive (mV)....:700
CPU Clock Skew (ps).......:0
IOH Clock Skew (ps)........:0
Performance Enhance.......:[Standard]
Extreme Memory Profile (X.M.P.)............:[Disabled]
System Memory Multiplier (SPD).............:x8
Memory Frequency (Mhz).......:1,600
DRAM Timing Selectable (sPD) ..............:[Quick]
Channel A, B, and C Standard Timing Control
Cas Latency Time.......:9
tRCD.........:9
tRP...........:9
tRAS.........:24
(All sub-timings on Auto for all 3 channels)
LoadLine Calibration.........:[Level 2]
CPU Vcore..........:1.325v
QPI/VTT Voltage.......:1.275v
CPU PLL.........: 1.80v
PCIE............:1.50 v
QPI PLL.........:1.10v
IOH Core.......:1.10v
ICH I/O........:1.50v
ICH Core.......:1.10v
DRAM Voltage..........:1.64v
DRAM Termination......:[Auto]
Ch-A Data Vref..........:[Auto]
Ch-B Data Vref.........:[Auto]
Ch-C Data VRef........:[Auto]
Ch-A Address Vref........:[Auto]
Ch-B Address Vref........:[Auto]
Ch-C Address VRef........:[Auto]
