So the problem is i did not attempt to overclock my system but when i start my system sometimes like 5 times in hundred,it boots up with overclocking failed.
I only remember selecting 1600 mhz in ram in bios because it was running at 1333 mhz.
Please help me, I'm worried because my mom uses that system now so nothing bad happens because she does not know how to fix things up.
he probably has the same issues, that i have with my M5A97 EVO R2.0, he probably just bumped up the multiplier, and set a manual voltage.
My board does the same wierd thing, wenn overclocking due multiplier. i cannot bump up my multiplier passed 22.5 x 200 = 4500Mhz. if i wanne bump my multiplier higher my board just does fail for some reason.
Try Northbridge overclocking deu bus ratio. instead of multiplier. With the bus ratio overclock, i was able to get my FX8350 stable at 4815Mhz and ram at 1926mhz.
Here is a more usefull guide for Northbridge overclocking.
http://www.youtube.com/watch?v=MckeAmnDeTk
i was lucky that i have an older FX8350, which was stable at 1.44V.
But remember, you cannot go that high as 240 on your bus ratio, because you are on a stock cooler everything will overheat.
i am just setting ram to its stock speeds ie. 1600mhz because it was running at 1333 mhz by default.i am telling this because that is why overclocking failed occurs.or i have bad ram or mobo.
