Overclocking Assistance
Hello Everyone!
I have been on the cusp of the pc community for most of my life and recently jumped in headfirst. I would say I am tech savvy not tech proficient. I can figure stuff out on my own eventually with rigorous googling. However, I have never overclocked my system before and would like to consult the higher powers (Y’all) beforehand.
I have an AMD RYZEN 9 9950X cpu, ASUS SFF RDY PRIME RTX5080 16G gpu, SUPERFLOW SF1000F LD3 FM 80+G ATX3 1000 watt power supply, MSI MAG X870E TOMAHAWK WF motherboard, G.SKILL 32G 2X D5 6000 C36 FX B ram, and an ARCTIC LIQUID FREEZER III 360 BK all in one cooler.
What there any specifics I should look out for when overclocking this system?
I have heard that the 9950X can overclocked to 200W but can my power supply sustain that with my 5080? How can I tell what my max wattage should be?
It seems like most people determine cpu speed by increasing the speed until the computer is unstable. IE crashing constantly, then backing down the speed. Is this the correct methodology? Is this the same methodology for overclocking gpu as well?
Online, my cpu specs list 5600 mega transfers as the max ram speed. My ram can go up to 8000 MT. Google has informed me I can use higher ram speed if I were to overclock my cpu. How would I determine my max ram speed after overclocking my cpu?
Do I need to adjust my cooler/fan settings? How? Or will it spin up automatically to cool my CPU?
Let me know!
Been a longtime fan of the channel. Happy to be here.
Thanks!
Hello to the world of overclocking!
To start with. Your power supply is well within spec to go overclock your system and to have fun with it. No worries there.
To start with, I would try and enable XMP/DOHC. Its your rams overclock profile its rated for.
You mentioned your ram has a 8000MT profile. See if that posts. If not. Step down the clock speed of the ram down until it posts and is stable.
Next. The best way to get the most out of your Ryzen Chip nowadays is to work with Curve Optimiser and PBO. https://www.youtube.com/watch?v=v9fL8XD2v2Q
Videos like this can help.
For the GPU, you can use ASUS GPU Tweak or MSI Afterburner. The logic there is to add core clock and memory clock until you experience crashes or artifacts in your games. There is a lot of guides out there. I personally like to watch JayzTwoCents for beginner friendly overclocking content in that regard.
In terms of cooling, you can adjust your fan curves within BIOS if you want to, but usually the coolers are set up decently out of the box nowadays. Especially the LF3 series from Arctic. But if you look up how to set up fan curves for overclocking. You should find info on what to do. Biggest criteria there is how loud you want your pc to be.
Anyways. Hope you have fun, happy number crunching and benchmarking!
Any tips on how not to fry my cpu and gpu?
Thanks!
Don’t increase voltages and be mindful of temperatures while stability testing.
Overclocking isn’t really about directly pushing clocks any more. Both CPU and GPU dynamically boost clocks but are constrained by temperature, power and voltage limits. Higher performance is achieved by reducing voltage at a given clock speed until instability sets in. For CPU this is done mostly using negative offsets in PBO curve optimizer. For GPU MSI afterburner and similar utilities also have a curve adjuster that allows you control the relationship between clock speeds and voltage.
Basically yes, but as mentioned it’s more about reducing voltage curves to enable higher levels of boost. Your CPU will likely be limited primarily by temperature so using curve optimizer to add a negative voltage offset will reduce power and temperature which will allow for higher clocks.
You’ll also need to decide if you want to run your memory over 6000MT.
