Gidday, mates!
I’m worried, but should i be?
(EDIT: tl;dr → stop worrying, it’s fine …see also the link in the 2nd reply)
My 3 Seagate IronWolf ST2000VN004-2E4164 2TB NAS HDDs all produce an alarming SMART report.
smartctl -x
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 117 099 006 - 130223486
3 Spin_Up_Time PO---- 096 096 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 18
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 084 060 030 - 238893354
9 Power_On_Hours -O--CK 088 088 000 - 10908 (*1.3 years)
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 100 100 020 - 18
184 End-to-End_Error -O--CK 100 100 099 - 0
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 100 000 - 0
189 High_Fly_Writes -O-RCK 001 001 000 - 607
190 Airflow_Temperature_Cel -O---K 074 056 045 - 26 (Min/Max 25/28)
191 G-Sense_Error_Rate -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 100 100 000 - 4
193 Load_Cycle_Count -O--CK 100 100 000 - 47
194 Temperature_Celsius -O---K 026 044 000 - 26 (0 20 0 0 0)
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
* i added this, wasn't included in the raw report
However, the extended self-test …
SMART Extended Self-test Log Version: 1 (1 sectors)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 10907 -
# 2 Short offline Completed without error 00% 10893 -
- What would be the reason for such a drastically elevated
Seek_Error_Rate&Raw_Read_Error_Rate- 130-240 million? The field name,ATTRIBUTE_NAME, tells me that it’s a hardware issue, maybe firmware? - Am i interpreting this correctly - the HDD itself maintains those
KCRSOPflags, right - it’s not somethingsmartctlenriches the report with, right? The drive firmware itself emmits thisprefailure warning, right? - Since the firmware seems to tell me that the drive will fail soon, I’d love to RMA these. The warranty period ends 2022-05.
