I am putting together a pc on that dual lga 2011 board from Asus, and I want use the SSd caching features and the onboard raid.
I am asking this as these drives will be used for a lot of miscellaneous things, rendering, file server...blah blah blah...I don't really want to list it as it is not important.
When used for such things, how often would I expect drives to fail? How often may affect my options for drive mounting/enclosures.
The options I have (that I know of) are:
Internal mounting - The Design XL R2 has 8 bays, enough for a boot ssd, cache ssd, and 6 WD Red drives, I am fine with this as long as the drives will not fail too often, but this will come at a cost to cooling performance.
"hotswap" 5.25 to 3.5 drive bracket - I can only use 3 of the 4 slots as one will be occupied, I can put 5 drives in these...nothing more it seems...Will allow me to swap if the drives happen to not live that long.
External Enclosure - I can get a 4 or 5+ enclosure and set it up using JBOD and then connect it through a eSATA pci bracket to my internal sata ports, (at which point I would use raid) --that is to avoid the poor raid on the enclosure, or the card it may come with-
NAS - Not really feeling this one though...I could get an 8 core SoC atom, 8GB ram, Zalman MS800 or Raidmax Seiran, FreeNAS, use ZFS, 60tb, cram it with hotswap brackets and proceed to destroy the world.
for external I would likely use one of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121405 has individual overheat LEDs for overheat, and individual LEDs for power
http://www.newegg.com/Product/Product.aspx?Item=N82E16816215345 NO overheat LED, power/indicator LEDs
http://www.amazon.com/iStarUSA-BPU-350SATA-BLACK-3x5-25inch-5x3-5inch-HotSwap/dp/B007VLDU8A Only one Overheat LEd for all drives
I would get a 3 drive (2 bay) variation for the raidmax if I were to do nas...and would lose the SuperMicro option.
For external boxes, I would probably get some thing like these:
4 drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16816856039 http://www.newegg.com/Product/Product.aspx?Item=N82E16816111203
5 drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16816111166
8 drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16816111168 http://www.newegg.com/Product/Product.aspx?Item=N82E16816132016
The only nice thing about the NAS solution is that I can move my OwnCloud server to that instead and keep to contained...not sure if that is really worth it...
But I am unsure if any of this is necessary at all anyway as I am unsure how often I'll need to replace drives, or if I'd really need more than 16TB (after raid)
