I have a 150MBit Internet connection but during the last few days I have noticed that I am limited to roughly 10-15Mbit. After doing a few tests I narrowed the issue down to the firewall and when looking at the dashboard and when browsing through my settings I noticed the WAN’s speed was set to 100baseTX .
I tried setting it to 1000baseT like LAN and IoT put this results in no Internet connection. When I directly connect a computer to the modem I am able to get my full Internet speed, so this does not seem to be the problem.
Additionally, I think the issue only occurred (was noticed) yesterday and I did have my full Internet speed a few days prior while no changes to the firewall or my network setup have been made, aside from installing the newest update.
Another problem I have noticed is that after a reboot of the firewall I sometimes did not get a WAN connection (just like when I used 1000baseT), but since I have manually set it to 100baseTX this seems to be solved now.
Any help on how to resolve this issue would be greatly appreciated!
Edit 1: The OPNsense version I am currently using is OPNsense 24.1.9_4-amd64 and FreeBSD 13.2-RELEASE-p11 on a AMD Ryzen Embedded V1500B (4 cores, 8 threads) machine.
Edit 2: Adjusted title
Edit 3: I set the interface to 1000baseT via the terminal but this results in no Internet connection. Setting it back to 100baseTX via the terminal also does not seem to work, but a restart and appropriate GUI settings seem to solve the problem. I have uploaded a log of this process here:
I have not visually checkes the cable, but the same cable connected to my notebook achieves 150Mbit. I will have to check which speed it negotiates though.
4d ago there was a major update of OPNsense so this might have been the culprit.
It seems to be more of a hardware issue than a software one. I’d check cables first then look at the NICs, then the switch itself. Last time I had a similar problem, the issue was the idiot that made the ethernet cables (me), as I had wired the RJ45 connectors wrong.
Thanks for the responses. So, I did use the same cable on my notebook and then switched to a different one also using a different port on the ISP’s modem:
~ ❯ ifconfig
en7: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=404<VLAN_MTU,CHANNEL_IO>
inet 192.168.0.94 netmask 0xffffff00 broadcast 192.168.0.255
nd6 options=201<PERFORMNUD,DAD>
media: autoselect (1000baseT <full-duplex>)
status: active
~ ❯ ifconfig
status: active
As you can see, both use 1000baseT <full-duplex> on my notebook, whereas both use 100baseTX <half-duplex> on my OPNsense firewall.
As you can see above, two different cables produce the same results and both the ISP modem as well as the firewall stand next to each other, so there was no need for wiring the cables myself.
How would you go about checking the NICs though? Any ideas?
Regarding the issue being a hardware one an not software related, I think my issues started appearing when I first installed OPNsense 24.1.9, so I am thinking drivers might be causing this
Let’s start with what NIC you are using. Even onboard NIC operate off a chipset of one type or another. When it comes checking the health of a NIC that one is more difficult. But you can start with a physical inspection looking looking at all the ports, pins and card itself (if it isn’t onboard), then move on to doing some preformance testing with tools like iperf, and beyond that you would need to test on a different NIC (gigabit NICs are cheap these days I suggest always keeping spare or two on hand).
Thanks! So I did have a look at the ports and I could see nothing suspicious. Aside from that, I am not sure if I am allowed to open the device without voiding the warranty as I am using a DEC740. (It would also be hard to replace the NIC itself I assume.)
That is good information, I didn’t realize you were running a commerical device and I was assuming you had a DIY solution. That being said if you are running a DEC device drivers shouldn’t be an issue. With that being said I did find a thread on the OPNSense forums relating the I211 chipset and some instablity. Which would be odd given that said chipset ships with one of their commercial products. Personally, I think it is worth a call to tech support, which you should have with your device as it comes with a commercial license.
Yeah, in the end I might have to contact tech support. I want to make sure though, that the problem is not anything on my side before contacting them and maybe even returning my device for repair.
I tried downgrading via sudo opnsense-revert -r 24.1.8 opnsense but the issue persists. (Have not tried downgrading the kernel since it is not advised.)
Yeah I can’t tell you about the customer support experience with them as I opted to build my own router rather than buy their commercial products and didn’t buy a commercial license to go with my router.
Maybe, that depends on the warranty on the hardware. It has been a while since I looked at their devices so I couldn’t tell you what that warranty period is.
I sort of have a Band Aid fix for the issue now by doing the following:
Since I have a DEC740 device I have three RJ45 ports at my disposal with Port 0 and Port 1 by default being assigned to LAN and set to 1000baseT <full-duplex> as well as WAN and 100base respectively.
So, I went into Interfaces>Assignments and set WAN to use igb2 (aka Port 2). Now, I do have 1000baseT <full-duplex> on my WAN again.
This makes me wonder though as the output below shows that all three ports use the same networking device. Thus, a driver/kernel issue can be ruled out, right?
