I should say up front that I’m very new to 10Gbps networking and not used to using iperf3 in UDP mode, but I tried it since that’s whats recommended with 10Gbps speed tests.
I’m getting these results. A few questions:
(1) I don’t understand what a packet loss on receiver (but not sender) means in this context;
(2) Whatever causes (1), why is it worse in -R (reverse) mode?
(3) Is this something I actually need to worry about, or is it normal?
System is a Dell Optiplex 5040.
- Intel(R) Core™ i5-6500 CPU @ 3.20GHz (4 cores, 4 threads) with 16 GB of DDR3 RAM;
- The LAN NIC is a 10Gbps Intel X520-DA2.
- Client and OPNSense are both set to MTU 9000.
Here are the test results:
% iperf3 -c 10.10.100.1 -u -i 1 -t 30 -b 10G -R
Connecting to host 10.10.100.1, port 5201
Reverse mode, remote host 10.10.100.1 is sending
[ 5] local 10.10.100.130 port 57660 connected to 10.10.100.1 port 5201
[ ID] Interval Transfer Bitrate Jitter Lost/Total Datagrams
[ 5] 0.00-1.00 sec 1.13 GBytes 9.74 Gbits/sec 0.013 ms 2316/138313 (1.7%)
[ 5] 1.00-2.00 sec 1.14 GBytes 9.76 Gbits/sec 0.007 ms 2360/138672 (1.7%)
[ 5] 2.00-3.00 sec 1.13 GBytes 9.75 Gbits/sec 0.013 ms 13581/149759 (9.1%)
[ 5] 3.00-4.00 sec 1.14 GBytes 9.76 Gbits/sec 0.008 ms 15122/151470 (10%)
[ 5] 4.00-5.00 sec 1.14 GBytes 9.76 Gbits/sec 0.015 ms 13145/149444 (8.8%)
[ 5] 5.00-6.00 sec 1.14 GBytes 9.76 Gbits/sec 0.010 ms 13621/149930 (9.1%)
[ 5] 6.00-7.00 sec 1.14 GBytes 9.76 Gbits/sec 0.008 ms 13310/149680 (8.9%)
[ 5] 7.00-8.00 sec 1.14 GBytes 9.75 Gbits/sec 0.013 ms 8859/145097 (6.1%)
[ 5] 8.00-9.00 sec 1.14 GBytes 9.75 Gbits/sec 0.009 ms 14099/150322 (9.4%)
[ 5] 9.00-10.00 sec 1.14 GBytes 9.76 Gbits/sec 0.009 ms 14747/151078 (9.8%)
[ 5] 10.00-11.00 sec 1.14 GBytes 9.76 Gbits/sec 0.006 ms 10456/146771 (7.1%)
[ 5] 11.00-12.00 sec 1.14 GBytes 9.76 Gbits/sec 0.014 ms 14305/150604 (9.5%)
[ 5] 12.00-13.00 sec 1.14 GBytes 9.75 Gbits/sec 0.011 ms 12657/148913 (8.5%)
[ 5] 13.00-14.00 sec 1.14 GBytes 9.76 Gbits/sec 0.007 ms 14013/150297 (9.3%)
[ 5] 14.00-15.00 sec 1.14 GBytes 9.76 Gbits/sec 0.010 ms 11611/147921 (7.8%)
[ 5] 15.00-16.00 sec 1.14 GBytes 9.76 Gbits/sec 0.006 ms 12737/149092 (8.5%)
[ 5] 16.00-17.00 sec 1.14 GBytes 9.76 Gbits/sec 0.015 ms 11856/148154 (8%)
[ 5] 17.00-18.00 sec 1.14 GBytes 9.75 Gbits/sec 0.012 ms 12527/148769 (8.4%)
[ 5] 18.00-19.00 sec 1.14 GBytes 9.76 Gbits/sec 0.009 ms 12571/148931 (8.4%)
[ 5] 19.00-20.00 sec 1.14 GBytes 9.75 Gbits/sec 0.008 ms 12030/148257 (8.1%)
[ 5] 20.00-21.00 sec 1.14 GBytes 9.76 Gbits/sec 0.014 ms 13026/149355 (8.7%)
[ 5] 21.00-22.00 sec 1.14 GBytes 9.76 Gbits/sec 0.008 ms 10384/146685 (7.1%)
[ 5] 22.00-23.00 sec 1.14 GBytes 9.76 Gbits/sec 0.011 ms 12672/148974 (8.5%)
[ 5] 23.00-24.00 sec 1.14 GBytes 9.76 Gbits/sec 0.008 ms 12339/148628 (8.3%)
[ 5] 24.00-25.00 sec 1.14 GBytes 9.76 Gbits/sec 0.008 ms 14110/150410 (9.4%)
[ 5] 25.00-26.00 sec 1.14 GBytes 9.76 Gbits/sec 0.011 ms 12614/148907 (8.5%)
[ 5] 26.00-27.00 sec 1.14 GBytes 9.76 Gbits/sec 0.010 ms 13323/149636 (8.9%)
[ 5] 27.00-28.00 sec 1.14 GBytes 9.76 Gbits/sec 0.013 ms 11472/147820 (7.8%)
[ 5] 28.00-29.00 sec 1.14 GBytes 9.75 Gbits/sec 0.008 ms 10721/146932 (7.3%)
[ 5] 29.00-30.00 sec 1.14 GBytes 9.76 Gbits/sec 0.012 ms 12844/149161 (8.6%)
[ 5] 0.00-30.00 sec 34.7 GBytes 9.93 Gbits/sec 0.000 ms 0/4450877 (0%) sender
[SUM] 0.0-30.0 sec 17 datagrams received out-of-order
[ 5] 0.00-30.00 sec 34.1 GBytes 9.76 Gbits/sec 0.012 ms 359428/4447982 (8.1%) receiver
% iperf3 -c 10.10.100.1 -u -i 1 -t 60 -b 10G
[ 5] local 10.10.100.130 port 62816 connected to 10.10.100.1 port 5201
[ ID] Interval Transfer Bitrate Total Datagrams
[ 5] 0.00-1.00 sec 1.16 GBytes 9.99 Gbits/sec 139634
[ 5] 1.00-2.00 sec 1.16 GBytes 9.96 Gbits/sec 139260
[ 5] 2.00-3.00 sec 1.16 GBytes 9.93 Gbits/sec 138837
[ 5] 3.00-4.00 sec 1.15 GBytes 9.86 Gbits/sec 137970
[ 5] 4.00-5.00 sec 1.16 GBytes 9.99 Gbits/sec 139768
[ 5] 5.00-6.00 sec 1.15 GBytes 9.91 Gbits/sec 138642
[ 5] 6.00-7.00 sec 1.15 GBytes 9.87 Gbits/sec 138065
[ 5] 7.00-8.00 sec 1.16 GBytes 9.99 Gbits/sec 139765
[ 5] 8.00-9.00 sec 1.15 GBytes 9.92 Gbits/sec 138687
[ 5] 9.00-10.00 sec 1.15 GBytes 9.88 Gbits/sec 138187
[ 5] 10.00-11.00 sec 1.16 GBytes 9.98 Gbits/sec 139553
[ 5] 11.00-12.00 sec 1.15 GBytes 9.92 Gbits/sec 138708
[ 5] 12.00-13.00 sec 1.15 GBytes 9.89 Gbits/sec 138435
[ 5] 13.00-14.00 sec 1.16 GBytes 9.96 Gbits/sec 139277
[ 5] 14.00-15.00 sec 1.15 GBytes 9.92 Gbits/sec 138711
[ 5] 15.00-16.00 sec 1.16 GBytes 9.93 Gbits/sec 138913
[ 5] 16.00-17.00 sec 1.16 GBytes 9.92 Gbits/sec 138782
[ 5] 17.00-18.00 sec 1.16 GBytes 9.93 Gbits/sec 138916
[ 5] 18.00-19.00 sec 1.15 GBytes 9.92 Gbits/sec 138767
[ 5] 19.00-20.00 sec 1.16 GBytes 9.93 Gbits/sec 138952
[ 5] 20.00-21.00 sec 1.15 GBytes 9.91 Gbits/sec 138671
[ 5] 21.00-22.00 sec 1.16 GBytes 9.93 Gbits/sec 138903
[ 5] 22.00-23.00 sec 1.15 GBytes 9.92 Gbits/sec 138704
[ 5] 23.00-24.00 sec 1.16 GBytes 9.93 Gbits/sec 138929
[ 5] 24.00-25.00 sec 1.16 GBytes 9.92 Gbits/sec 138821
[ 5] 25.00-26.00 sec 1.16 GBytes 9.93 Gbits/sec 138840
[ 5] 26.00-27.00 sec 1.16 GBytes 9.92 Gbits/sec 138795
[ 5] 27.00-28.00 sec 1.16 GBytes 9.93 Gbits/sec 138860
[ 5] 28.00-29.00 sec 1.16 GBytes 9.93 Gbits/sec 138854
[ 5] 29.00-30.00 sec 1.15 GBytes 9.92 Gbits/sec 138734
[ 5] 30.00-31.00 sec 1.16 GBytes 9.93 Gbits/sec 138902
[ 5] 31.00-32.00 sec 1.15 GBytes 9.92 Gbits/sec 138748
[ 5] 32.00-33.00 sec 1.16 GBytes 9.93 Gbits/sec 138874
[ 5] 33.00-34.00 sec 1.16 GBytes 9.92 Gbits/sec 138831
[ 5] 34.00-35.00 sec 1.16 GBytes 9.93 Gbits/sec 138892
[ 5] 35.00-36.00 sec 1.15 GBytes 9.92 Gbits/sec 138776
[ 5] 36.00-37.00 sec 1.16 GBytes 9.93 Gbits/sec 138886
[ 5] 37.00-38.00 sec 1.15 GBytes 9.92 Gbits/sec 138702
[ 5] 38.00-39.00 sec 1.16 GBytes 9.93 Gbits/sec 138921
[ 5] 39.00-40.00 sec 1.16 GBytes 9.93 Gbits/sec 138845
[ 5] 40.00-41.00 sec 1.16 GBytes 9.92 Gbits/sec 138819
[ 5] 41.00-42.00 sec 1.16 GBytes 9.92 Gbits/sec 138775
[ 5] 42.00-43.00 sec 1.16 GBytes 9.93 Gbits/sec 138880
[ 5] 43.00-44.00 sec 1.16 GBytes 9.92 Gbits/sec 138839
[ 5] 44.00-45.00 sec 1.15 GBytes 9.92 Gbits/sec 138684
[ 5] 45.00-46.00 sec 1.16 GBytes 9.93 Gbits/sec 138967
[ 5] 46.00-47.00 sec 1.16 GBytes 9.93 Gbits/sec 138875
[ 5] 47.00-48.00 sec 1.15 GBytes 9.92 Gbits/sec 138733
[ 5] 48.00-49.00 sec 1.16 GBytes 9.92 Gbits/sec 138787
[ 5] 49.00-50.00 sec 1.16 GBytes 9.93 Gbits/sec 138898
[ 5] 50.00-51.00 sec 1.16 GBytes 9.93 Gbits/sec 138833
[ 5] 51.00-52.00 sec 1.16 GBytes 9.93 Gbits/sec 138878
[ 5] 52.00-53.00 sec 1.15 GBytes 9.91 Gbits/sec 138656
[ 5] 53.00-54.00 sec 1.16 GBytes 9.93 Gbits/sec 138894
[ 5] 54.00-55.00 sec 1.16 GBytes 9.93 Gbits/sec 138935
[ 5] 55.00-56.00 sec 1.15 GBytes 9.92 Gbits/sec 138771
[ 5] 56.00-57.00 sec 1.16 GBytes 9.93 Gbits/sec 138819
[ 5] 57.00-58.00 sec 1.15 GBytes 9.91 Gbits/sec 138670
[ 5] 58.00-59.00 sec 1.16 GBytes 9.94 Gbits/sec 138950
[ 5] 59.00-60.00 sec 1.16 GBytes 9.93 Gbits/sec 138926
[ 5] 0.00-60.00 sec 69.3 GBytes 9.93 Gbits/sec 0.000 ms 0/8330906 (0%) sender
[ 5] 0.00-60.00 sec 69.2 GBytes 9.90 Gbits/sec 0.006 ms 26911/8328876 (0.32%) receiver
