Opinion and suggestions on build
This will be my computer for the next few years. I am going to use it for school and free time. I want it to be reliable and quite as well as powerful. I am not doing any gaming. Here is the link:
http://pcpartpicker.com/p/WHdcLk
do aio cpu cooling ever leak, can the 970 support 2 4k monitiers smoothly for no gaming, will it quite and reliable
*ps I know there is not alot of storage but I use google drive
Fantastic build that is basically my pc but i have a 3820 and a gtx 780.
Your build looks good although I don't think you need and 860w platinum power supply for this build you would be fine with a 750w gold if you dont plan on adding another video card. If you really want and 860w platinum go with seasonic its about $20 cheaper than that corsair and seasonic builds corsair so it is a great psu. Other than that its a great build.
Uhm, what about white or black RAM, the red is really the only red in your system and that would be a littlebit to little color for me. (I know you do not have a window but you still know it's there).
And 1700 bucks and no harddrive? really? A 1TB WD green is like 48 bucks! There will be most likely situations where you need to backup a 64 gig sd card/thumbdrive to your machine and then you probably do not want to delete a game to have room for it.
Do AIOs ever leak? - YES. They can leak and there are models which are reported to leak more than others.
As far as I've heard a 970 will drive 3 monitors in 4k. Working will be fine, gaming ... not so much with dual 4K, but you said you do not intend to do so.
If you aren't gaming you could easily get away with getting a cheaper graphics card that has a few display port outputs.
What are you using it for?
