Openwrt on proxmox
I cannot get my openwrt vm on my proxmox to activate the ax200 wifi that has been passed through to the vm from the proxmox host.
iw list is returning nl80211 not found. and even if I enable the radio openwrt states device not found.
This is the guide I used to create the vm:
This is the guide I used to enable iommu on proxom host:
This is the guide I used to install ax200 firmware:
I further installed these packages:
pciutils, iw, iwinfo, kmod-cfg80211, iwlwifi-firmware-ax200, wpad-basic
the command iw list is giving me nl80211 not found.
lspci is showing the ax200 wifi nic
the host is a cwwk n100 4 port computer. its using a intel ax200 wifi card.
I’m at a loss as to what to do next.
Any ideas?
Can’t remember the switches off hand, but would you be able to post the output from lspci, with current kernel driver that the system is using for it?
Like
lspci -S 02:00.0 -knvv
Or whichever it is?
It is showing the device in the lspci, but if it’s using the wrong driver, perhaps there is a way to change that?
I swiched the -S flag to -s
# lspci -s 00:10.0 -knvv
00:10.0 0280: 8086:2723 (rev 1a)
	Subsystem: 8086:0080
	Physical Slot: 16
	Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Interrupt: pin A routed to IRQ 11
	Region 0: Memory at fea90000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [c8] Power Management version 3
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
		Address: 0000000000000000  Data: 0000
	Capabilities: [40] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 unlimited
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W
		DevCtl:	CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+ FLReset-
			MaxPayload 128 bytes, MaxReadReq 128 bytes
		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 5GT/s, Width x1, ASPM L1, Exit Latency L1 <8us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
			ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 5GT/s, Width x1
			TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range B, TimeoutDis+ NROPrPrP- LTR+
			 10BitTagComp- 10BitTagReq- OBFF Via WAKE#, ExtFmt- EETLPPrefix-
			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
			 FRS- TPHComp- ExtTPHComp-
			 AtomicOpsCap: 32bit- 64bit- 128bitCAS-
		DevCtl2: Completion Timeout: 16ms to 55ms, TimeoutDis- LTR+ 10BitTagReq- OBFF Disabled,
			 AtomicOpsCtl: ReqEn-
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
			 EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
			 Retimer- 2Retimers- CrosslinkRes: unsupported
	Capabilities: [80] MSI-X: Enable- Count=16 Masked-
		Vector table: BAR=0 offset=00002000
		PBA: BAR=0 offset=00003000
lspci: Unable to load libkmod resources: error -2
I was getting a libkmod error so I’m including the below
# lspci
00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
00:01.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II]
00:01.2 USB controller: Intel Corporation 82371SB PIIX3 USB [Natoma/Triton II] (rev 01)
00:01.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 03)
00:02.0 VGA compatible controller: Device 1234:1111 (rev 02)
00:03.0 Unclassified device [00ff]: Red Hat, Inc. Virtio memory balloon
00:05.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge
00:10.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
00:12.0 Ethernet controller: Red Hat, Inc. Virtio network device
00:13.0 Ethernet controller: Red Hat, Inc. Virtio network device
00:1e.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge
00:1f.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge
01:01.0 SCSI storage controller: Red Hat, Inc. Virtio SCSI
# lspci -vv
	Subsystem: Red Hat, Inc. Qemu virtual machine
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:01.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II] (prog-if 80 [ISA Compatibility mode-only controller, supports bus mastering])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Region 0: I/O ports at 01f0 [size=8]
	Region 1: I/O ports at 03f4
	Region 2: I/O ports at 0170 [size=8]
	Region 3: I/O ports at 0374
	Region 4: I/O ports at f0a0 [size=16]
	Kernel driver in use: ata_piix
00:01.2 USB controller: Intel Corporation 82371SB PIIX3 USB [Natoma/Triton II] (rev 01) (prog-if 00 [UHCI])
	Subsystem: Red Hat, Inc. QEMU Virtual Machine
	Latency: 0
	Interrupt: pin D routed to IRQ 11
	Region 4: I/O ports at f040 [size=32]
	Kernel driver in use: uhci_hcd
	Interrupt: pin A routed to IRQ 9
00:02.0 VGA compatible controller: Device 1234:1111 (rev 02) (prog-if 00 [VGA controller])
	Subsystem: Red Hat, Inc. Device 1100
	Region 0: Memory at fc000000 (32-bit, prefetchable) [size=16M]
	Region 2: Memory at fea94000 (32-bit, non-prefetchable) [size=4K]
	Expansion ROM at 000c0000 [disabled] [size=128K]
	Kernel driver in use: bochs-drm
	Subsystem: Red Hat, Inc. Device 0005
	Physical Slot: 3
	Latency: 0
	Interrupt: pin A routed to IRQ 10
	Region 0: I/O ports at f000 [size=64]
	Region 4: Memory at fd600000 (64-bit, prefetchable) [size=16K]
	Capabilities: [84] Vendor Specific Information: VirtIO: <unknown>
		BAR=0 offset=00000000 size=00000000
	Capabilities: [70] Vendor Specific Information: VirtIO: Notify
		BAR=4 offset=00003000 size=00001000 multiplier=00000004
	Capabilities: [60] Vendor Specific Information: VirtIO: DeviceCfg
		BAR=4 offset=00002000 size=00001000
	Capabilities: [50] Vendor Specific Information: VirtIO: ISR
		BAR=4 offset=00001000 size=00001000
	Capabilities: [40] Vendor Specific Information: VirtIO: CommonCfg
		BAR=4 offset=00000000 size=00001000
	Kernel driver in use: virtio-pci
00:05.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge (prog-if 00 [Normal decode])
	Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Region 0: Memory at fea95000 (64-bit, non-prefetchable) [size=256]
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: e000-efff [size=4K] [16-bit]
	Memory behind bridge: fe800000-fe9fffff [size=2M] [32-bit]
	Prefetchable memory behind bridge: fd400000-fd5fffff [size=2M] [32-bit]
	Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: [4c] MSI: Enable- Count=1/1 Maskable+ 64bit+
		Masking: 00000000  Pending: 00000000
	Capabilities: [48] Slot ID: 0 slots, First+, chassis 03
	Capabilities: [40] Hot-plug capable
	Subsystem: Intel Corporation Device 0080
	Physical Slot: 16
	Subsystem: Red Hat, Inc. Device 0001
	Physical Slot: 18
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
	Latency: 0
	Region 0: I/O ports at f060 [size=32]
	Region 1: Memory at fea96000 (32-bit, non-prefetchable) [size=4K]
	Region 4: Memory at fd604000 (64-bit, prefetchable) [size=16K]
	Expansion ROM at fea00000 [disabled] [size=256K]
	Capabilities: [98] MSI-X: Enable+ Count=4 Masked-
		Vector table: BAR=1 offset=00000000
		PBA: BAR=1 offset=00000800
	Physical Slot: 19
	Latency: 0
	Region 0: I/O ports at f080 [size=32]
	Region 1: Memory at fea97000 (32-bit, non-prefetchable) [size=4K]
	Region 4: Memory at fd608000 (64-bit, prefetchable) [size=16K]
	Expansion ROM at fea40000 [disabled] [size=256K]
00:1e.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge (prog-if 00 [Normal decode])
	Region 0: Memory at fea98000 (64-bit, non-prefetchable) [size=256]
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: d000-dfff [size=4K] [16-bit]
	Memory behind bridge: fe600000-fe7fffff [size=2M] [32-bit]
	Prefetchable memory behind bridge: fd200000-fd3fffff [size=2M] [32-bit]
	Capabilities: [48] Slot ID: 0 slots, First+, chassis 01
00:1f.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge (prog-if 00 [Normal decode])
	Region 0: Memory at fea99000 (64-bit, non-prefetchable) [size=256]
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: c000-cfff [size=4K] [16-bit]
	Memory behind bridge: fe400000-fe5fffff [size=2M] [32-bit]
	Prefetchable memory behind bridge: fd000000-fd1fffff [size=2M] [32-bit]
	Capabilities: [48] Slot ID: 0 slots, First+, chassis 02
	Subsystem: Red Hat, Inc. Device 0008
	Physical Slot: 1
	Latency: 0
	Region 0: I/O ports at e000 [size=64]
	Region 1: Memory at fe800000 (32-bit, non-prefetchable) [size=4K]
	Region 4: Memory at fd400000 (64-bit, prefetchable) [size=16K]
Thanks Trooper_ish, it took me a while to figure out that the firmware was not being loaded. I assumed that iwlwifi-firmware-ax200 would work but it did not.
I had to install kmod-iwlwifi and then download the firmware from kernel.org and then copy the firmware to /lib/firmware.
I downloaded the firmware from:
https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/iwlwifi-cc-a0-59.ucode
I hope this helps others.
