i have openvpn running on a bare metal pfsense firewall. accessing internal resources from the internet works fine. no problems setting up users, they all work fine from the internet.
my problem is this:
lan clients cannot connect to openvpn on said pfsense instance. i want to do this to make sure .ovpn files actually work before sending to the person in need of it.
EX:
connecting from 192.168.0.45 always fails with a timeout (i can telnet to the open vpn port and it connects then fails, because , telnet) .
the exact error is " TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
TLS Error: TLS handshake failed"
this has to be something simple i am missing somehow. perhaps a firewall rule?
