OpenRecoveryScript Help!
I recently rooted my att galaxy s4 using the pwn method through the sd card and terminal emulator. I know it is rooted and have downloaded many root apps but I badly want to get cyanoginemod. Iv'e tried to get Clockwork Recovery or TWRP in different ways but it won't work. When I boot into download mode it just stays there and I end up having to rip the battery out and restart the phone. I have tried Rom manager and Goo Manager; Rom manager thinks I have Clockwork recovery but I can't boot into it, and I can't even download anything on Goo Manager. Am I making some noob mistake...how can I get a recovery flashed? Any help would be great!
Thanks,
Bentonjdame
I'm not very familiar with samsung devices, but on most devices you need to unlock the bootloader before you can flash things.
I don't think Samsung provides a bootloader unlock though so you could try the following ways to flash it:
since you have Terminal emulator you could try running these commands after downloading the recovery.img and placing it on your sdcard. Also, change "recoveryimagename" to whatever the name of the recovery image is.
su
dd if=/dev/block/mmcblk0p21 of=/sdcard/recoverybackup.img
dd if=/sdcard/recoveryimagename.img of=/dev/block/mmcblk0p21
make sure you get EVERY SINGLE LETTER RIGHT if you decide to do it that way, dd got the nickname "data destroyer" for a reason. If for some reason that doesn't work you will have a backup image of the recovery on your sdcard named "recoverybackup" that you can use "dd" to flash back (in case of a worst case scenario).
Or you could download ODIN, and try flashing it through there but I have no experience with it so I can't help you with that.
