Hi
I want to host a open air cinema this summer. There are going to be around 100 peoples so I need a big screen. The best way is a projector. I don’t know a lot about projectors when it comes to admitted light or contrast. I need your help.
As of now I plan to use my own Benq W1000 as renting a projector is quit expensive. The cinema will start around 11 pm so the sky should be dark by then, even in July. Will this work with that projector. I used https://www.projectorcentral.com/BenQ-W1000-projection-calculator-pro.htm to calculate but I don’t know all the units and what they stand for. 4m (13feet) screen would be fine for me. Can I do that?
Thanks for your answer
Janick Spielmann
