Any one out there running Arch or Antergos specifically that has successfully install onionshare from the AUR? I keep getting errors during the install.
ERROR: Failure: ValueError (invalid version number '0.12.2-dev')
Traceback (most recent call last):
File "/usr/lib/python3.6/site-packages/nose/failure.py", line 39, in runTest
raise self.exc_val.with_traceback(self.tb)
File "/usr/lib/python3.6/site-packages/nose/loader.py", line 417, in loadTestsFromName
addr.filename, addr.module)
File "/usr/lib/python3.6/site-packages/nose/importer.py", line 47, in importFromPath
return self.importFromDir(dir_path, fqname)
File "/usr/lib/python3.6/site-packages/nose/importer.py", line 94, in importFromDir
mod = load_module(part_fqname, fh, filename, desc)
File "/usr/lib/python3.6/imp.py", line 234, in load_module
return load_source(name, filename, file)
File "/usr/lib/python3.6/imp.py", line 172, in load_source
module = _load(spec)
File "<frozen importlib._bootstrap>", line 675, in _load
File "<frozen importlib._bootstrap>", line 655, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 678, in exec_module
File "<frozen importlib._bootstrap>", line 205, in _call_with_frames_removed
File "/home/t/.cache/pacaur/onionshare/src/onionshare-1.0/test/onionshare_test.py", line 20, in <module>
from onionshare import OnionShare
File "/home/t/.cache/pacaur/onionshare/src/onionshare-1.0/onionshare/__init__.py", line 23, in <module>
from . import strings, helpers, web, onion
File "/home/t/.cache/pacaur/onionshare/src/onionshare-1.0/onionshare/web.py", line 39, in <module>
if Version(flask_version) < Version('0.11'):
File "/usr/lib/python3.6/distutils/version.py", line 40, in __init__
self.parse(vstring)
File "/usr/lib/python3.6/distutils/version.py", line 137, in parse
raise ValueError("invalid version number '%s'" % vstring)
ValueError: invalid version number '0.12.2-dev'
Ran 3 tests in 0.223s
FAILED (errors=3)
==> ERROR: A failure occurred in check().
Aborting...
:: failed to build onionshare package(s)
