Ohh, I like the power loss protection, via supercap…
Looks like the capacitor may be replaceable, it I don’t know how common that type is to buy separately…
I see a few images, no idea what that shows ![]()
(actually, I do, but I’m an electronics guy. not everyone here is
You could have described what you see, then… ![]()
To me, it looks like Hot-swap like drive trays, with carrier boards inside, that are marked up as interposers allowing m.2 drives to be plugged in to U.2 slots in a computer…
Well, the boards say U.2 to M.2, but the ssd looks more like a M.2 sized drive, to me…
Unless I am mistaken; I am not a computerist…
I’ve own(ed) and/or run a few forums and mail groups and I expect if someone posts an image (or more) to at least provide some info for those who can’t see these images
Just to be courteous to your visually impaired fellow geek ![]()
I’m not visually impaired, but I am very lazy. ![]()
I just purchased 2 for my supermicro server. I have a pair of icydock adapters but I don’t like them. M.2 NVMe/M.2 Sata SSD card to U.2(SFF-8639)/U.3(SFF-TA-1001)/SATA(Serial ATA) adapter
Wow, that shop has so many handy devices
Have you received items from them before?
His are they? Would you recommend, or was it must a web example?
First time buying from that website. But I have had few of their pcie risers and an oculink cable. There is a seller called JMT on Amazon that sells them but they aren’t always prime.
You beat me to the punch by a month. I just ordered the similar starter pack:
I have 2 plx 88096 (96 lane pcie switch gen4 configurable for x4 bifurcation, or x8, or x16…) with a bunch of u.2 hotswap storage bays
end goal being 40x nvme gen4 in a 4u chassis ;D
Im not visually impaired, but I am very lazy. ![]()
I’m so lazy that at work I’m constantly insisting on things go in a certain way. This is because it is to much work to find misplaced stuff.
I am very intrigued. I have about 10x Samsung 990 Pro (2 and 4tb) that I’m trying to connect to my Epyc 7J13 4U GPU server. Initially I was using the Asus PCIe to 4x NVME adapter but they are very wide and block the air to my dual 5090. The ASRock Rome2T has 7x PCIe but with the gpus + nvme adapter + Intel 710 nic I don’t have a lot of options on where to put the gpus and nvmes.
One alternative was the Icydock (or the SilverStone Technology FSM08B-MS) with a ton of slimsas cables. Another option would be a PCIe adapter (under the gpu or right after) to “a" nvme or in this case U.2 tray.
How are you liking the U.2 adapter (hot swap, capacitor, …) and what about the active PCIe splitter a few replies up?
Thanks!
