I’m not sure if this is the right section for my question, as the onboard sound is just a small part of a motherboard and would also fit into the Sound Gear section.
tl;dr - how do I know (beforehand) if the impedance of headphones are too much to handle for the onboard sound?
My M40x (35ohm) are creaking a lot when I move my head, to the point where it’s just not a good experience using them (cause I would have to sit completely still). Lubrication didn’t work that well (used just a little machine oil). They’re also not fit for longer sessions (it gets hot under the earcups and the clamping force is still too much, even after 2 years).
My cousin’s K601 (discontinued) on the other hand are soooo much more comfortable. No creaking, no sweating and no pain. The only problem was that they were not really “loud”, due to high impedance (120ohm), used on my Asrock H87 Pro4 back then (Realtek ALC892). The K612 Pro are basically the same.
According to PCGamesHardware my Aorus AX370 Gaming 5 does not have a headphone amp (ALC1220).
Will the K612 Pro be too difficult to drive for my motherboard? I don’t really want to spend extra money on an ext. DAC/Amp right now.
