Old linux felt faster than it does today
It was a lot faster it had less code and ran well on a pentium M.
Now not so much.
If someone can unearth their time capsule with the some Pentium from 2005 you’ll realize it wasn’t faster, you just had more time back then :stuck_out_tongue:
There are however different requirements on software today, your browser runs a sandbox/container for every site you visit and the video you watch is no longer 320p.
The Operating Systems of today does a lot more behind the scenes, this is certainly true.
Another thing that is true, however, is that we’re running on an OS design at least twenty years old (possibly even thirty or forty), created in a time before there were true parallelism in a computer. These days, even our mid-range smartphones have quad cores, not to mention what could be done with more general GPGPU processing calls. The game has changed completely, and yet we still program like it’s the nineties.
So do I believe we can do better with the tech we have? Hell yeah, definitely. But such a change would take years to get right, would have to involve hundreds of driven souls, and most probably require a lot of funding. Google tries with their new kernel, as do other giants out there. None are even close to finding a solution yet, or they would have already bragged about it.
I believe we will soon see a new breakthrough in OS kernels, but it’ll be a few years more before the research is there. :slight_smile: The only question is, do we still call it Linux when we’ve ejected Linux from the OS…?
Well not only an OS on itself need more resources.
But applications are also designed to utilize the resources of the hardware better.
Just look at webrowsing, i mean browsers have become terrible resource hogs.
But i would say that resource management on linux is still significantly better then on windows.
on linux if it doesn’t feel snappy its mostly because of a bad configured DE or you are using gnome on old hardware, which gnome can’t handle well, especially g3.
installed mint with cinnamon on an super old thinkpad, super snappy.
but to the initial question: someone need to beats the hell outta devs so they don’t use all the ressources that are there. i mean, browsing the web with any modern browser vs. w3m or such thing is insane… same with most software for the consumer fields is just wild…
Have you tried running fedora Linux on an m.2 SSD with all partitions formatted to f2fs? Everything is lightning fast, the animations aren’t a problem like most people are saying here. Most people run ext4 because that is the default filesystem on most distros. It isn’t optimized for ssd’s and over time will slow down due to inefficient use of the data sectors.
I have no problem what so ever with f29 on ssd. so putting that on m.2 would not improve anything since the problem, in my opinion, is how the DE works and how badly the DE works on the hardware especially older hw/laptops.
So, I guess, getting a DE that doesn’t need that much on ressources is the best way to get that clutch snappyness than upgrading hardware when its a software problem.
as with most of the de’s out there and many of the browsers they are being designed for the newer technology. older equipment is being abandoned as it no longer can handle the newest gadgets.
developers design the software based on the requirements needed now and abandon the resources older equipment needed in favour of the new tech.
its called planned obsolescence!
how many years have companies did this? Far more than we care to admit!
Microsith is one of them, all you need to do is look at the requirements of every version made and it tells you the minimum requirements!
microsoft holds stock in almost every computer manufacturer so when you buy a new pc your spoon feeding them, double so when you buy their os.
and they are not the only ones!
so your faced with the choice Either keep on using the older hardware or buy all new.
you dont usually find the optimum requirements listed so when you need to update you go out and buy the newest toy just to run the software.
sure there are work-around tactics that you can do to still utilize older hardware, but they are not publicized anywhere other than the tech forums.
add the fact that many users will not post the questions about working around older technology to avoid ridicule that they will just go out and buy new.
when you customize a distro to run on a piece of older hardware and re-spin it you’ve recreated a distro for use on that older hardware and newer.
No, it’s called keeping with the times.
Planned obsolescence is when they go out of their way to make old stuff explicitly not work, despite the fact that it would be powerful enough. If older hardware just can’t keep up, then it is not planned obsolescence. It is simply not powerful enough.
I lol’d at this.
Although according to MS, the requirements for W10 is the same as it was W7 actually. So they haven’t changed the requirements for about 11 years.
Have you tried to run windows on the minimum system requirements? Or the recommended.
It’s not that great of a time.
Ohh I dunno about that. The CPU scheduler alone can have a massive impact on how the entire system “feels” and lately, what you get out of the box (pre tweaking), is pretty horrid for a desktop. Works yes but far from ideal.
It’s not even a question so much about SSD vs hard disk or memory. There are bugs burried in X / NVIDIA drivers where the entire rendering pipeline can stall and don’t even get me started on how it is we’re now in 2019 yet brwosers STILL refuse to render at anything more then potato.
165Hz montior yet 60fps (and lower).
That alone is critical to how most users see a system.
Just install a gnome extension that reduces animation speed if that’s your problem. You don’t have to go switch to an entirely separate de/distro just because the animations aren’t quick enough. To say running f2fs on an m.2 ssd would make no difference is just plain dismissive.
so either the solution is to fix it with software or to fix it with hardware?
my point is that old hardware doesnt like to play nice with latest gnome-* shit so DE feels old and boring.
good luck to add a m.2 to a 15 year old thinkpad instead of installing another distro/de
That last line is incredibly generous. It is horrific, and only approaches a consistently smooth experience on a good deal higher than base spec.
You can get a decent experience 75% of the time with a few minor upgrades, but it will still falter in a few cases randomly.
You can say the same about Linux, to be honest. Running Debian, Ubuntu, or Fedora at 2GB of RAM is atrocious and makes me want to shoot myself.
I have a Windows 10 VM that acts as a Hyper-V controller with 2 CPUs and 4GB of RAM.
Rarely do I sit and think “My, how slow”
It works as intended and designed.
Its mainly because the OS itself isnt the only thing using more resources. Programs are designed to better utilize the hardware nowadays. Browsers now heavily leverage system resources RAM,CPU,GPU etc. So do scientific programs and even basic photo editing programs leverage resources more efficiently but also in greater amounts
I’ll have to give it another try. I know the system requirements have been creeping from the 128MB required when I started using Linux, but I didn’t realize you’ll have a bad time with 2GB of ram.
2019 and running any type of GUI
REEEEEEEEEEEEEEEEEEEEEEEEEEEE
Lol. I started using linux with 4 MB. It was slow. 8 MB made X actually usable. sort of.
how times change.
But really. today my phone has 2 GB of RAM, people whining that they can’t run 2019 desktop software on 2 GB of memory, when 8 GB is what… 50 bucks (at a guess, before people go correcting me saying its like 30)… need a reality check.
1990’s slackware on a 486 dx/2 50 was lightning fast
Doom had no sound :disappointed_relieved:
Mint flew on my Phenom x3, then I upgraded to a newer version and it got slower.
One thin you could try is get an version that is 6 months or a year newer then when your hardware came out. Linux is awesome on older hardware but newer or less popular. My 7850k apu was a pain on linix but my 8350k+gtx 770 had zero problems
Linux is a labor of love, how many “labor of love” projects sit in the garage, never completed?
My APU now has a R7-250 for dual gfx, why would anyone bother to write code and troubleshoot code for a set-up few people have, or want.
