Time and memory capacities move on.
Yes, linux was (subjectively) faster back in the 90s (i started using Linux in 1995) and early 00s, but it did less. Maybe not less from the âWhat can i do in an applicationâ perspective, but shitty 3d support, poor media support, single channel audio, poor integration between applications, no/poor hot plug and auto detect of devices, etc.
Also, SMP support back then was a lot worse.
As linux gets feature parity with windows, performance will reach similar levels. There is a hard floor with regards to features vs. memory consumption vs. performance, and despite the whining by everybody, Microsoftâs application PERFORMANCE is not as terrible as some might suspect.
The security is trash, but performance wise Windows generally isnât that bad when you take into account what is actually going on underneath.
Also, the old adage âhardware is cheap, programmer time is expensiveâ was never more true than today. So what if it uses a couple of GB (more) of RAM (due to appropriate levels of abstraction and generalisation of the code into multipurpose libraries) when actual applications that do useful things are thus available and as a result, easier to program.
Iâm not saying âwho cares about optimisationâ, but when the average desktop these days for a power user is 16-32GB of RAM and up, its far preferable to have an application written that needs say 8, than not have an application at all because the libraries that consume the memory and the high level language features that consume the memory arenât available.
Sure, if youâre an edge case where you need to optimise heavily for memory consumption - go for it. But memory is plentiful in 2019. The data-sets we are working with (HD/4k video, high res photos, high definition audio, etc.) are FAR larger than the executable code these days.
That said, iâm running a Ryzen 7 with KDE and 32 GB of RAM under Ubuntu and memory consumption is generally under 8 GB with a few VMs running in the background.
Maybe youâre mistaking âbuffer/cacheâ as actual consumed RAM?
