OCuLink will not train on FW AI MAX 395
I’m troubleshooting an OCuLink eGPU on a Framework Desktop with
Ryzen AI Max+ 395.
Current setup:
  • Internal PCIe x4 slot
  • PH492-1W adapter, PCB marked VER:1.2
  • RGEEK F9G eGPU dock
  • Included OCuLink cable, approximately 30 cm
  • Intel Arc GPU
  • Ubuntu, kernel 7.0.0-44-generic
The same dock, cable, and GPU work together on another machine.
On the Framework, the GPU does not appear in lspci. The affected
root port is 0000:00:03.2.
Kernel messages:
pci 0000:00:03.2: broken device, retraining non-functional downstream link at 2.5GT/s
pci 0000:00:03.2: retraining failed
Root-port status with the BIOS PCIe speed set to Gen 3:
LnkCap: Speed 8GT/s, Width x4
LnkCtl: ASPM L1 Enabled; LnkDisable- CommClk+
LnkSta: Speed 2.5GT/s, Width x4
Train+ SlotClk+ DLActive-
LnkCtl2: Target Link Speed: 8GT/s
Tests so far:
  • Forcing Gen 3 did not resolve it.
  • Connecting a display directly to the eGPU did not resolve it.
  • Selecting the runtime ASPM performance policy did not resolve it.
  • Booting with pcie_aspm.policy=performance pcie_port_pm=off
    did not resolve it. Both parameters were verified in /proc/cmdline,
    but the port still reports ASPM L1 Enabled.
  • Previous M.2-to-OCuLink adapter attempts also failed to establish
    an active link.
Has anyone encountered this specific Train+ / DLActive- failure
on the Framework Desktop, especially with an Intel Arc GPU?
Are there known firmware limitations involving PCIe link training,
reference clock, or reset timing with OCuLink adapters? Is there
a recommended diagnostic or a validated PCIe-slot adapter?
do you have another pcie device to test?
