OCR in pdf reader(opensuse-okular)
Hi,
Is there a pdf reader on linux that can do OCR(Optical Character Recognition).
I currently use Okular on opensuse leap, but when the pdf is only scanned I cannot copy the text. The only option I get is to copy the picture of the tex.
kind regards,
oldman
ps. I am not sure if this post should go into Linux-other or into the linux-helpdesk
Never played around with this but learn everyday I guess...
Okular seems to work fine albeit being a bit awkward as in random spaces and whatnot on the output, or is the issue in scanning a physical document?
Just painting some text then pasting seems to work ok.
You can try opening the file with Libreoffice writer it will OCR it and you can copy the text but only line by line.
This does however not work if the document is a scanned document. For this I would need OCR, but thanks for the reply.
Thanks for the reply but this is not an option, since I really do not want to open a file in libreoffice every time I have to copy something from it
Well its up to you. You can also check "tesseract" an open source google project for OCR but it is only back end you can use it through CLI. For a frontend app you will have to search around.
And, in my opinion, “normcap” is a handy 3rd party integration.
