So i have the powercooler hd radeon 7770
What do you guys think will be a decent oc to play games like BF4 and watch dogs at better frame rate and settings then i currently do.
I have msi afterburner and it says my
Core clock: 1100 MHz
Memory clock: 1125 MHz
Thanks for the help :)
OCing varies from card to card. Go online and search for what results people are getting to get a vague idea of what you can do.
A very quick overclocking guide:
Reset clocks to default.
Slowly bump up core clock and test with various games or stress tests. Once your games start crashing/artifacting(it'll be really obvious, dw), dial it back about 5-10%. Record the number.
Repeat with only memory clock.
Bump both core and memory clock to the recorded values. Test for stability. If not stable, add a little bit of voltage or slowly reduce the core & memory clocks until stable.
what stability test would you recomend and would loading minecraft be adequate because it's fast ?
I use minecraft as one of my tests. However, I use forge and load up sonic ether shaders, and bump up all the settings. I also run TF2, Thief, GMod, and other games I play.
Furmark is a good stress test.
