For my upcoming build, I've decided on the Asus Maxiumus V Formula motherboard and I really like the Phantom 410 case. My question is if the Formula would fit.
I know that the Formula is an E-ATX motherboard, but it's only 13mm wider than standard ATX. I'm not worried about the board covering the cable-routing holes, but I'm wondering if the case would conflict with the board at all.
Any and all suggestions would be much appreciated.
Thanks :D
