The stupid NZXT Havik fan is in the way of my ram. In order to install everything, the Havik fan has to sit a little higher than it normally would. How much do you think this matters and what can I do to rectify it?
It think it really matters much. You could try low-profile memory, slim fan, or just use one fan in a pull configuration. Personally, I'd just let the fan sit higher, or just use one fan in pull.
