NZXT Apollo
So, I bought this case about 1 year ago. And if you don't know the specs, it has 3 120mm fan ports, 2 intake, 1 exhaust.
Anyways, When I bought the case with my build and upgraded the CPU to a Q9550 and the fan to an Ultra X Wind the temps were idle around 32-34c.
Well, just yesterday I moved into my new place and the temps in the house are about 5-10 degrees cooler than my old house. So just being curious I checked my temps on my 9550 and they were 21c sometimes 19 at idle. I was just amazed by how much room temperature affects the computer temps. Also, The Apollo case is amazing imo. For $70 total you get something well worth it and better than all the others in the same price range.
Edit: Just to put it out there, my GPU temps also went from 60c idle to 48c.
So youre saying that you live in 17-18-19 ish c? lol.
Haha, well right now it's about 23c (73f) room temperature and the case temps are the same.
Its physically impossible to get temps below room temperature if youre air cooling.
Oh well it might be that cold in here. Doesn't seem like it though, to me.
Nice case, but for around 70 there's at least two i can think that is better.
It was 59.99 but with tax and shipping it was 70ish
The only other ones I could find would only hold 80mm fans.
NZXT Lexa S, CM RC690
The first one I didn't see reviews on when I looked so I didn't bother when buying. And the Nvidia edition of the Cooler Master case is pretty sweet. Actually thought about upgrading to it sometime soon.
