Hopefully I can fit the ups / switch and my centos router on the cart also…
does the wife know yet?
No.
Right now she’s pissed I didn’t get her texts while I was trying to cut grass.
good luck
were rosewill brothers
I love how fucking tiny that case is
actually I think the front of yours is different than mine.
What model do you have
Fixed your image link.
I think my ITX case is APEX?
Maybe they use the same OEM?
I have noticed that after 5.0.11-200.fc29
checking disk IOPs via snmp is broken…
…Will edit this post again when another kernel version fixes it…
Have fun with your new toys
(The foam insert chokes airflow like crazy though and the stock Bok fans that come with the case aren’t that good either :P)
TIL
Interesting.
They’re identical internally
I’m fine with that as long as it is good for filtering dust. (which it should be)
And as long as the CPU/disk temps are lower than they were in the other case. (which they have been)
I’m happy.
I ordered some 2.5 to 3.5" drive adapters for the SSDs that I moved from the old cases, so right now the drives are just laying inside the case. (pic is few posts below)
Had these things for a while, but never shared.
When the deals popped up… I couldn’t resist.
Photoshop
On the forum… Is what I meant
