I just received my order from Amazon and I purchased the Sokiwi model, all metal enclosure with a sliding cover to install the storage device, they even give you a thermal pad/strip for sinking the heat.
It works fine but didn’t do any testing yet, the issue is the very short USB cables.
They give you both a USB A to USB C and a USB C on both ends, depending on your configuration.
I will have to look at getting longer USB C cables.
