Hi, I’ve just installed Pop_os on my desktop after using it on my laptop for a few months. My issue is that my Nvidia settings are not sticking after I reboot. I’m using Nvidia setting because I’m using custom resolutions for my side monitors. They are 1920x1080, and my main monitor is 3440x1440, so in order for everything to look good I always run them at 2560x1440 in windows. I can manage to get the monitors to run at 2560x1440 trough the Nvidia settings. I start by opening nvidia-settings with sudo, then change settings as desired, and save it as /etc/X11/xorg.conf.d/20-nvidia.conf.
However it wont stick on reboot, I have also tried to follow this.
I’m running driver version 435.21
This is my 20-nvidia.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 435.21
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Ancor Communications Inc ASUS VE278"
HorizSync 24.0 - 92.0
VertRefresh 50.0 - 85.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 1080 Ti"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Coolbits" "4"
Option "Coolbits" "8"
Option "Coolbits" "12"
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-5"
Option "metamodes" "DVI-D-0: 1440x2560_60 +6000+0 {rotation=right, viewportin=1440x2560, ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, HDMI-1: 2560x1440_60 +3440+1120 {viewportin=2560x1440, ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, DP-2: 3440x1440_95 +0+1120 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
