I have a laptop with Intel integrated graphics and a rather weak Nvidia dGPU (NVS 5200M). A few updates ago I started having a problem where Xwindows would not load if Optimus was enabled and the Intel GPU was the primary GPU. I worked around this by toggling Optimus off and using the Nvidia as the primary GPU.
I was hoping a recent update of the Nvidia drivers (loaded from RPMFusion) would correct this problem, but the situation ended up even weirder. If I enable Optimus, the desktop loads but as it loads I see the message:
NVIDIA kernel module not found. Failing back to Nouveau.
And the desktop loads. I confirmed that the nouveau and i915 modules were loaded with lsmod. The weird thing is that nouveau is blacklisted, both in the kernel options and in /etc/modprobe.d/.
OTOH if I try to disable Optimus and boot with the Nvidia dGPU alone, I get no desktop at all. If I try āmodprobe nvidia.koā I get a message that the kernel module canāt be found in /usr/lib/(kernel version). Even if I hard link the nvidia modules in /usr/lib/(kernel version), modprobe still says it canāt find the bloody thing. (Is there a command like ldconfig for kernel modules?) Even if I provide an absolute path to the kernel module files, modprobe still complains that it canāt find them.
I also tried āsudo dnf reinstall xorg-x11-drv-nvidia akmod-nvidiaā which accomplished absolutely nothing.
This is not an urgent issue. The Nvidia dGPU is so weak, that the Intel driver actually provides roughly equivalent performance. Iām just trying to wrap my head around the Fedora driver stack and understand whatās going on.
To recap, my questions are:
Why canāt I load nvidia.ko and nvidia-drm.ko with modprobe manually?
Why does modprobe complain that it canāt find the *.ko files, even though theyāre right bloody there.
Is there some kind of utility that needs to be run so that Fedora can find its kernel modules (like say ldconfig)?
Why is nouveau loading even though itās blacklisted?
Fedoraās kernel updates for 4.17.7 REALLY broke a lot of things. Downgrade to 4.17.3 for now, because even on the vanilla kernel, you canāt update past 4.17.8 or Nvidia DKMS wonāt build.
The nouveau issue may be an issue with the new version of dracut. Downgrade dracut.
I strongly recommend downgrading to 4.17.3, since using dnf downgrade goes all the way back to 4.16.3. If youāre on Ryzen, you want the 4.17 optimizations.
[root@e6430 ~]# dnf downgrade kernel-4.17.3-200.fc28
Last metadata expiration check: 1:44:47 ago on Sat 28 Jul 2018 11:37:23 PM CDT.
No package kernel-4.17.3-200.fc28 available.
Error: No packages marked for downgrade.
Last metadata expiration check: 1:44:57 ago on Sat 28 Jul 2018 11:37:23 PM CDT.
No package kernel-4.17.3 available.
Last metadata expiration check: 1:45:02 ago on Sat 28 Jul 2018 11:37:23 PM CDT.
No package kernel-4.17.3-200 available.
Still no worky. As I mentioned earlier, the performance improvement isnāt worth the trouble, so I just completely removed nvidia and blacklisted nouveau. And the Intel driver performs quite a bit better now. Thanks anyway.
Ah, I didnāt read that youāre on a laptop. Thatās different with Nvidia Optimus. That has a completely different set of graphics driver installation instructions.
Have you tried reinstalling the Nvidia driver with the iGPU access disabled? And can you even do that from your laptopās BIOS?
If I disable Optimus in UEFI, the Nvidia dGPU becomes the primary and sole GPU. Butā¦itās relatively power hungry, and Iād like to use the laptop on battery for more than an hour. I do have an extended 9-cell battery, but itās got a Fermi GPUā¦
Wait⦠Fermi is compatible with Nouveau. You may not get top of the line performance, but using Nouveau on Fermi is actually a good option, since Nvidia has ended support for Fermi with their official driver stack.
Unfortunately itās far worse than ānot top of the line performance.ā In this case, the Intel driver completely smokes the nouveau driver. No point in using the dGPU unless I can use the nvidia driver. Windows is a different story, though.
You donāt need to disable SELinux⦠donāt know where would suggest that.
I would suggest trying to use the negativo17 repo for Nvidia drivers. Iāve found them better packaged and easier in the past and they provide a dkms package which I think works better than the kmod versions.
Make sure your stuffs all up to date and youāve undone any blacklisting or holding back packages you did here if you try it.
