Hello there,
As I build the server discussed in another thread, there is another build I was curious on how to accomplish.
Idea:
- Build a cable homelab where I can “stream”/broadcast specific shows and movies to my TV’s as if it were an actual TV channel. Example - a Twilight Zone channel that just runs through each episode chronologically and then loops after ending. Another for Clone Wars, Andy Griffith, MASH, etc.
Goals for this build:
To have movies and TV optical media (to be ripped) able to just be played on the TV as if it were a TV station broadcasting. (Background noise, set to play chronologically as my OCD will want to not shuffle episodes but see them one after the next)
Be able to setup multiple channels (about a dozen).
Must haves:
-Not a Netflix XP but the kind where you’re younger brother went to go get snacks and the show came back on you yell so he didn’t miss what was next.
-Can flip through channels with remote as if they were actual channels.
-Just runs 24/7, loops after ending.
-Multiple Channels
-As little DIY as possible (ex. I do not want to be rewiring anything, soldering, etc.)
-$4k budget, (willing to push it a little +/- $2k if necessary)
-No PLEX.
-Privacy. Ideally any services used do NOT have access to what I am running or playing at any given time.
-No WIFI in the house so everything is wired via RJ45 Cat6A cables or COAX (I live in an old neighborhood with not so many modern houses/construction unless I DIY’ed it at mine)
Nice to haves:
-Have one or as minimal source devices as possible sending multiple signals
-Pause / Next Episode, Previous Episode, etc.
-Guides for each channel (update themselves)
-Digital Playback to Cable COAX preferred, HDMI as possible
-Minimal Power Draw and noise.
-$1-2k budget
Here is so far what I have seen so far:
So I watched this video a while ago after researching possibilities:
but this is all old CRT’s and using much older equipment and requires some rewiring. So not quite in line with what I am looking to do.
and also came across this one then too which was much more in line with my goals:
However, it’s basically a bunch of Raspberry Pi’s (not against) running each channel. Hoping to have smoother playback, and less devices if possible. A few other things don’t quite align.
I was thinking of building a small NAS (6-12 core, ~32GB RAM, SSD Storage) and running each channel in a media player on a VM each that would output to a different HDMI port to then go into an RF modulator each (with a different channel for each) to then go into splitters that connect back into the single COAX that goes to the entire house.
Good idea or is there a more efficient way to go about it?
Also, I may just be dumb since I have never used one but do RF modulators only output a single channel or multiple? That could help a TON!
TLDR: Want to broadcast my own home cable channels to the whole house via COAX. Have some ideas but not sure the most efficient way nor what exact hardware so advice on my proposed setup would be appreciated.
Any and all advice welcome! ![]()
