Not Sure if this CPU Cooler Fits
i heard this cpu cooler is pretty big and i was wondering if it would fit when i put all the parts inhttp://pcpartpicker.com/p/Ck0X
http://pcpartpicker.com/p/Ck0X sorry did not use a space
should fit in the case just fine, but the ram is a problem. vengeance ram has huge heat spreaders, I would look for something with smaller heat spreaders, as they don't do anything anyways.
Should fit no problem, id suggest a Define R4 unless you really need the extra 2 Hard Drive slots or need to fit XL-ATX Motherboards, and the R4 Can Definitley fit it as it has some of the most height clearence for CPU coolers of any Mid tower case.
what kind of ram do you suggest?
