So as I understand my motherboard (Gigabyte Vision B550 D-P) doesn’t allocate enough resources for my SR-IOV device (a S7150). However they still release BIOS updates. I was wondering on the best way to approach the Gigabyte support on asking them to release a new BIOS.
make sure you have done the following
disable CSM
Enable above 4G decoding
Enable Resizable bar/Smart access memory
Above 4G decoding and resizble bar were already enabled. I’ll look for CSM settings.
I’m no expert but to my knowlege mmio had something to do with barspace, been a while since I last looked it up, might be unrelated
Okay those were the settings there already. Unfortunately I’ve got a new error now:
[ 45.966307] gim info:(gim_init:149) Start AMD open source GIM initialization
[ 45.966428] gim info:(gim_init:151) GPU IOV MODULE - version 0.0
[ 45.966527] gim info:(gim_init:154) Copyright (c) 2014-2017 Advanced Micro Devices, Inc. All rights reserved.
[ 45.966866] gim info:(parse_config_file:217) AMD GIM fb_option = 0
[ 45.966969] gim info:(parse_config_file:217) AMD GIM sched_option = 0
[ 45.967075] gim info:(parse_config_file:217) AMD GIM vf_num = 0
[ 45.967178] gim info:(parse_config_file:217) AMD GIM pf_fb = 0
[ 45.967395] gim info:(parse_config_file:217) AMD GIM vf_fb = 0
[ 45.967423] gim info:(parse_config_file:217) AMD GIM sched_interval = 0
[ 45.967455] gim info:(parse_config_file:217) AMD GIM sched_interval_us = 0
[ 45.967488] gim info:(parse_config_file:217) AMD GIM fb_clear = 0
[ 45.967518] gim info:(init_config:341) INIT CONFIG
[ 45.971006] gim info:(set_new_adapter:572) curr allocated at 00000000b48f1c7e
[ 45.971008] gim info:(set_new_adapter:579) SRIOV is supported
[ 45.971010] gim info:(set_new_adapter:587) found PCI bridge device
[ 45.971010] gim info:(set_new_adapter:588) found: 00:3.1
[ 45.971029] gim info:(set_new_adapter:608) mmio_base = 000000003ea85c4f
[ 45.971034] gim info:(set_new_adapter:610) doorbell = 000000009f9d2e46
[ 45.971037] gim info:(set_new_adapter:612) pf.fb_va = 00000000ec590ec3
[ 45.971046] gim info:(sriov_is_ari_enabled:164) PCI_SRIOV_CAP = 0x00000002
[ 45.971047] gim info:(sriov_is_ari_enabled:174) PCI_SRIOV_CTRL = 0x00000010
[ 45.971048] gim info:(sriov_is_ari_enabled:177) PCI_SRIOV_CTRL_ARI is set --> ARI is supported
[ 45.971048] gim info:(program_ari_mode:441) Read bif_strap8 = 0xffffffff
[ 45.971049] gim info:(program_ari_mode:446) program_ari_mode - Set ARI_Mode = PF_BUS
[ 45.971050] gim info:(program_ari_mode:456) Write bif_strap8 = 0xff9fffff
[ 45.971050] gim info:(gim_read_rom_from_reg:181) Reading VBios from ROM
[ 45.971054] gim error:(gim_read_vbios:239) Invalid AMD VBIOS
[ 45.971058] gim error:(set_new_adapter:631) Failed to read vbios
[ 45.971058] gim info:(gim_probe:91) AMD GIM probe: pf_count = 0
I’ll need to look for a VBIOS for my S7150 and I’ll be unable to really test the motherboard BIOS in the meantime (at least as it concerns to SR-IOV).
