Just wondering if these temperatures, speeds etc seem normal, as I feel the temperature seems to get a bit high:
I have only been playing DayZ, yet achieved:
- 99% GPU load
- 1162.7MHz max clock speed
- 76C max temp
- 57% max fan speed
This is all according to GPU-Z, which was running in the background whilst I was playing.
According to Nvidea's website: http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-670/specifications
The official max operating temp of GTX 670 is 97°c. So I'd say your card is within a more than adequate max load temperature. I think that seems to be the target load temps of the Direct CUII cooling system anyway since my Asus HD 7970 Direct CUII maxes out 75°c at max load (@ stock speeds of 925mhz core/5500mhz memory). I've since moved up from those clock speeds so to maintain 70-75°c I've changed the maximum fan speed to 60+%.
Ah great - didn't know that. Thanks!
