Normal behavior for two new fans?
I recently installed two new Corsair basic 120mm rgb fans on top of the case, they’re plugged in seperately in their own headers (not daisy chained) the 4 pin power headers on the board are clearly labled “top fan1 and top fan2” same goes for the 3 pin rgb headers so installation should be sound. Initially the new fans wouldn’t sync rgb wise with the current ones and they would start and stop then kick into full speed for no reason, installing a bios update fixed this, I was also getting a fan error on every bootup. Everything seemed fine except I noticed only the top fans would stop for about 6 seconds when the windows login appeared then would start back up and stay that way. This happens almost every boot if windows is in balanced mode, it will happen occasionally in performance mode, the other three fans always stay on including cpu, just ones I recently installed do this. Recently the fan error returned out of nowhere, so I reinstalled bios and put it back on performance, also turned off fastboot in bios and windows in case hardware isn’t being properly recognised on start up, error is gone but fans will still occasionally stop again on login, so I’m stumped, psu should be more than adequate. Any ideas?
Does these fans have a 3- or 4-pin connection? And are the headers configured accordingly (DC or PWM)?
Maybe also check the minimum RPM (low-level) of these headers, as it sounds like the fans are stopping because they are told to run very low but cannot handle that.
I’ve had similar issues in the past.
Reset CMOS and then check that the fans are set correctly to either PWM or DC voltage. Also I recommend using a program like “Fan Control” to control your fans in Windows
