No shutdown past 4.14.66
Ryzen r5, 1600
corsair vengeance lpx 2x4gb
msi b350m bazooka
Using the latest Manjaro (I also had this problem with every kernel in Mint) and any kernel above 4.14.66 makes the system hang on shutdown. They range from different numbered systemd-udevd to watchdog “not installed” errors and hangs.
the most prevalent being
systemd-udevd[352]: Giving up on workers to finish
systemd-udevd[352]: Event loop failed: connection timed out
I’m new-ish to linux.. I know basic commands to get me installed and gaming, install/uninstall.. If any other information can help, lemme know what commands to run and I’ll do so..
kernel isn’t unstable or anything.. It seems fine on 4.14.66.. Just per Wendell, I’d like to update to the latest kernel if I can.. A hard shutdown isn’t a pain to do, it’s just cringeworthy coming from a long past of using Windows. I have all my Blizzard games running flawlessly thanks to level1linux and Wendell giving me that final push out of Windows. I’d like to stay on Linux now :). Any help is greatly appreciated. I know Ryzen v1 isn’t in an infancy with Linux anymore – so I’m hoping this has been ironed out at some point and I’m just missing it. Thanks again.
Edit: I do not have the segfault bug. Or so the testing script didn’t report any. (Really didn’t wanna rip my cooler off to check the CPU date – just built the thing and she’s not even due for a cleaning yet)
New errors.. ran
journalctl -b -1 -p3
and came out with
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2421 ‘/devices/pci0000:00/0000:00:07.1/0000:20:00.2’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2528 ‘/devices/system/cpu/cpu8’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2529 ‘/devices/system/cpu/cpu9’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2527 ‘/devices/system/cpu/cpu7’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2518 ‘/devices/system/cpu/cpu0’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2526 ‘/devices/system/cpu/cpu6’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2524 ‘/devices/system/cpu/cpu4’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2522 ‘/devices/system/cpu/cpu2’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2523 ‘/devices/system/cpu/cpu3’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2520 ‘/devices/system/cpu/cpu10’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2521 ‘/devices/system/cpu/cpu11’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2525 ‘/devices/system/cpu/cpu5’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: seq 2519 ‘/devices/system/cpu/cpu1’ killed
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [371] failed while handling ‘/devices/system/cpu/cpu8’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [361] failed while handling ‘/devices/system/cpu/cpu7’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [363] failed while handling ‘/devices/system/cpu/cpu6’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [366] failed while handling ‘/devices/system/cpu/cpu9’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [360] failed while handling ‘/devices/system/cpu/cpu2’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [370] failed while handling ‘/devices/system/cpu/cpu4’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [379] failed while handling ‘/devices/system/cpu/cpu5’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [356] failed while handling ‘/devices/system/cpu/cpu11’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [374] failed while handling ‘/devices/system/cpu/cpu1’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [380] failed while handling ‘/devices/system/cpu/cpu10’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [382] failed while handling ‘/devices/system/cpu/cpu3’
Aug 29 09:38:04 Spa-Des-BX1 systemd-udevd[344]: worker [384] failed while handling ‘/devices/system/cpu/cpu0’
from kernel 4.18.4-1
Put the tag helpdesk in your post under tags. It might help with getting your post seen by more eyes.
I’m unable to select it for some reason… Even when I attempt to create a new post in helpdesk, it doesn’t show up in the search for tags.
I got you @spades
