No rear panel audio on GIGABYTE B550 VISION D Linux
Note: heavily borrowing from the following post that seems related but isn’t identical (kernel update did not fix my issue as it did in this post): Has anybody gotten audio working in Linux on Aorus X570 Master?
I recently installed PopOs on my system running a GIGABYTE B550 VISION D. Everything is working well except the rear/font panel audio. Pulse detects it (as seen the the screen shot below) but I get no sound output. If I swap out to to the HDMI output I get audio from my monitors (using proprietary NVIDIA drivers version 510).
Rear/font panel audio works fine in windows. Any thoughts? Thanks!
Pulse Volume Control:
Output of uname -a:
Output of lspci -nn -vvv :
Output of pacmd list-sinks :
index: 10
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: IDLE
suspend cause: (none)
priority: 9039
volume: front-left: 13222 / 20% / -41.71 dB, front-right: 13222 / 20% / -41.71 dB, rear-left: 9169 / 14% / -51.25 dB, rear-right: 9169 / 14% / -51.25 dB, front-center: 1065 / 2% / -107.35 dB, lfe: 29089 / 44% / -21.17 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 34.76 ms
max request: 20 KiB
max rewind: 20 KiB
monitor source: 12
sample spec: s16le 6ch 44100Hz
channel map: front-left,front-right,rear-left,rear-right,front-center,lfe
Surround 5.1
used by: 0
linked by: 1
configured latency: 40.00 ms; range is 0.50 … 1999.82 ms
card: 4 <alsa_card.pci-0000_55_00.4>
module: 27
properties:
alsa.resolution_bits = “16”
device.api = “alsa”
device.class = “sound”
alsa.class = “generic”
alsa.subclass = “generic-mix”
alsa.name = “ALC1220 Analog”
alsa.id = “ALC1220 Analog”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0”
alsa.device = “0”
alsa.card = “3”
alsa.card_name = “HD-Audio Generic”
alsa.long_card_name = “HD-Audio Generic at 0xef400000 irq 148”
alsa.driver_name = “snd_hda_intel”
device.bus_path = “pci-0000:55:00.4”
sysfs.path = “/devices/pci0000:00/0000:00:08.1/0000:55:00.4/sound/card3”
device.bus = “pci”
device.vendor.id = “1022”
device.vendor.name = “Advanced Micro Devices, Inc. [AMD]”
device.product.id = “1487”
device.product.name = “Starship/Matisse HD Audio Controller”
device.string = “surround51:3”
device.buffering.buffer_size = “1058304”
device.buffering.fragment_size = “529152”
device.access_mode = “mmap+timer”
device.profile.name = “analog-surround-51”
device.profile.description = “Analog Surround 5.1”
device.description = “Starship/Matisse HD Audio Controller Analog Surround 5.1”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-pci”
ports:
analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
properties:
active port: <analog-output>
Problem fixed with update to Feb 2022 bios.
