No post on budget dual EPYC2 build
thought I did my homework on compatible parts to take advantage of these cheap eBay EPYC CPUs flooding in… price for performance can’t be matched in this class of system. I decided to go this route because my existing system already has 256GB of DDR4-2400 ECC RDIMMs which I’ve read multiple places works ok albeit a little slower performance. Picked up a Supermicro H11DSI-NT ver1 and a pair of 48c Gen2 EPYC 7K62 CPUs. Flashed the Rev1 Rome mod bios but no go.
Look up “AMD EPYC vendor lock-in” :roll_eyes: :face_with_symbols_over_mouth:
I was wondering about that but see that other vendors advertise them as unlocked
I take it that if they are used and most likely pulls from a major vendor “Dell, HP, Lenovo” then they are most likely locked? I’ve contacted the seller to see what they say
Yes, by and large those CPU’s are locked. Unfortunate, but that’s why they’re so cheap :moneybag:
my seller says they are unlocked… other vendors I asked say theirs are unlocked too. The H11DSi board obviously works with them because some Chinese sellers have a package deal with these CPUs and model motherboard… either I have a dead board or the BIOS needs some special version or mod that I’m unaware of. I have a cheap naples cpu on the way “that very well may be locked” that I will try before throwing in the towel with this board.
[For Supermicro H11DSI REV2.0 SP3 Motherboard +2PCS EPYC 7k62 2.3GHz 48C/96T CPU Processor #beach - YT/shorts/knwIlOQUxHc
from the video I can see ver 2.3 on the BIOS…
