Hi there!
I am new to networking and using networking equipment. Very new.
I recently purchased an Supermicro A2SDi-H-TF motherboard and two 32GB Samsung DDR4 2400 ECC RDIMMs. The board has an onboard X553/X557-AT Intel NIC and provides dual 10Gbe RJ-45 sockets.
However, I don’t have any 10Gbe switches or routers. I have a 2.5Gbe Hasivo S1100P-8GT switch.
When installing TrueNAS-SCALE-22.02.4, I cannot connect to the web GUI and TrueNAS cannot connect to the network through the Hasivo 2.5Gbe switch. I get this:
Here are the things I have tried to get this working with the 2.5Gbe switch:
- I tried installing the Intel ixgbe kernel drivers suggested by Patrick from STH for a similar Supermicro A2SDi-H-TP4F motherboard with the same Intel X553 NIC. The driver version Patrick mentioned as working (5.0.4) is no longer available from Intel, so I tried installing the latest version (5.16.5) from Intel’s website. I had to follow the README instructions in the tarball instead of Patrick’s instructions because Patrick’s instructions didn’t work at the
sudo insmod ./ixgbe
step. The executable in Patrick’s instructions did not exist. Even so, these Intel Linux drivers did not help. - I tried installing TrueNAS-13.0-U2 (TrueNAS Core). This is the BSD version, and it supposedly had the Intel X553 drivers first. However, when I installed TrueNAS Core, I got the following:
This effectively turned out to be the same result as with TrueNAS Scale (which is the Linux version of TrueNAS). I don’t know how to use BSD or install BSD drivers, so I did not try that. I would like to stick with TrueNAS Scale for the Docker containers anyway. - I tried using a different Cat-6 cable that I know works on another TrueNAS Scale 22.02.4 box. This box uses an ASUS ROG B550-I motherboard with an onboard Intel I225-V 2.5Gbe NIC, and that box is able to auto-negotiate with the Hasivo 2.5Gbe switch at 2500Mbs:
Even so, this cable did not work with the A2SDi-H-TF box and TrueNAS Scale. I have the same result.
Finally, I pulled out my TP-Link TL-SG108E 1Gbe switch and tried that. With this switch, TrueNAS Scale and TrueNAS Core are able to connect to the network, get a valid IP address, and I am able to access the TrueNAS Scale web GUI.
I have many questions. Am I doing something wrong? Is the X553 Intel NIC not capable of auto-negotiating 2.5Gbe? Do the Linux ixgbe drivers not support 2.5Gbe? Am I the silliest nutcase you have ever heard of?
I would love to hear your comments. Thanks for reading!
